Home > Message Board > Press Releases > Archive through April 23, 2007 > How to upload video to YouTube with F...
How to upload video to YouTube with Freeware YouTube Uploader
[ Create New Press Release ] [ Reply ] [ Edit ]
Step 1. Download Free YouTube Uploader
This is the clearly free program. There are no spyware or adware. It's absolutely safe to install and to run!
Step 2. Launch Free YouTube Uploader
Follow Start > All Programs > Free YouTube Uploader or just click the program icon on the desktop.
The interface is very simple and self explaining. There are the field for an input file or a YouTube URL, the field for an output path, and lists with preconfigured profiles.
Step 3. Trim Video
Click the Trim video... button along the bottom of the interface to open the new window.
Use navigation line and special buttons to set start and end selection markers position.
Click Apply & Close to switch back to the main program window.
[img]http://www.soft29.com/images/freeware/youtube-uploader-2.jpg[/img]
Step 4. Select input video file
Click the Browse... button to select a video file from your computer.
Next fill Title, Description and Tags the fields, which helps other Internet users to find your video on YouTube.
Click Next >
Note: Free YouTube Uploader converts your video to YouTube friendly format with optimal size and quality!
Step 5. Select a Category for Your Video
On this step select you should select a video category your video belongs to and select your video laguage.
You are ready now. Click the "Upload Video" button now.
Step 6. Uploading Video
Wait several minutes.
The uploading time depends on your video duration and Internet connection speed.
Note: It may take just several seconds to upload video to YouTube, but if your connection is slow, it may take 10 - 20 minutes to upload video. Please be pacient.
Step 7. Your Video is Ready
As soon as the uploading is completed YouTube Uploader will show your video location link and HTML code. Use this code, if you want to place this video to your site.
Or just copy and paste the public URL link to your broweser address bar to see it on YouTube.
Note: Let YouTube several minutes to update its system and publish your video online.
Resource: http://www.soft29.com/freeware/youtube_uploader.htm
Relevant Product Info
Home > Message Board > Press Releases > Archive through April 23, 2007 > How to upload video to YouTube with F... [ « Previous ] [ Next » ]
