Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through May 09, 2007 >
Defrag Study Indicates Increased Backup Performance
| Posted by Colleen Toum... on Thursday, April 26, 2007 - 02:58 am: |
As data backup involves file access, fragmentation of data files can have a profound impact on the length of time a backup procedure may take. Fragmentation means that the data on the disk is not contiguous. Instead, it is scattered around the disk in bits and pieces. And, while the data can still be accessed, it is obvious that it is going to require additional seek time when the data from a particular file is not all in one location on the disk.
Testing has found that the time required to back up data from a typical hard drive volume to backup devices can be decreased and the backup data transfer rate increased by a defrag job prior to backup. Furthermore, directory consolidation has a direct additional benefit in backup and data transfer rates. The study showed improvements in backup performance up to 69% (decrease in total back up time)—less than one half of the time for the fragmented system. Similarly, backup data transfer rates increased up to 69% over that for the fragmented state—nearly 1.7 times as fast.
Combining the benefits of directory consolidation with I-FAAST (Intelligent File Access Acceleration Sequencing Technology) improved backup data transfer rates and backup times in the network disk backup trials for ARCServe by a total of 70%.
Diskeeper® Corporation, an industry-leading developer of system performance tools such as Diskeeper 2007, performed these series of rigorous tests to determine the effects of fragmentation on backup operations and the benefits of defragmentation on various systems. The results showed that in addition to defragmenting the case, consolidating directories had a further benefit on backup performance. Backup times for ARCServe were improved by an additional 3% for the local disk backup, and an additional 41% for the network disk backup.
Contact: Colleen Toumayan
Email: ctoumayan@diskeeper.com
Phone: 800-829-6468
