Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through May 09, 2007 >
AV Toolbox product line expands with the new CS-320 Scan Converter
| Posted by Debbie Heath on Tuesday, May 01, 2007 - 07:54 am: |
CORIO™ Technology from TV One
MARGATE, Kent, 1st May 2007 - The new CS-320 Scan Converter was designed with high performance and ease of use in mind, with many automatic features that take the hassle out of set up and use of the product. The award-winning CORIO® technology is the backbone behind this unit however with a retail price-tag of just £165 (€243) you can be sure that the CS-320 is arguably the best “value for money” PC to Video Scan Converter (Down Converter) available on today’s market.
The CS-320 is compatible with both PC and Mac computers and has automatic incoming resolution detection. The advanced 4-Line Digital Flicker Elimination Circuitry provides crisp, clear images up to 1024 x 768 computer input resolution without line dropping, at any vertical refresh rate, although the maximum input resolution available is higher still at 1600 x 1200. Video outputs are switchable between PAL and NTSC and are simultaneously provided in Composite, S-Video and RGBS formats, as well as the computer monitor loop-through.
AutoSet, an exclusive CORIO™ feature, takes all of the hassle out of setup by automatically sizing and positioning the computer image to fit exactly on the video screen. All of the functions of the unit can be controlled via the front panel push buttons or through an Infrared Remote Control and all of the settings are stored in a non-volatile memory and are retained even when power is switched off. The Zoom feature available on the CS-320 allows the user to enlarge a quarter of the computer screen to fill the entire video screen and the Pan feature allows the user to move around to any area they choose.
The CS-320 Scan Converter retails at just £165 (€243) and is available now to order.
The entire AV Toolbox product line can be viewed on their website www.avtoolbox.co.uk, alternatively you can contact their European Sales and Technical Department on +44 (0) 1843 873307 or at sales.europe@avtoolbox.com.
