Home > Message Board > Press Releases > Archive through 2008 > Archive through May 09, 2007 > Trends UD-10 USB Audio Converter brings Audiophiles-Grade USB transport to
Hong Kong, May 8, 2007 - ITOK Media Limited's innovative Hi-Fi brandĄ§Trends
Audio" (www.TrendsAudio.com) launched the innovative USB transport - Trends
UD-10 USB Audio Converter. It includes unique balanced digital AES/EBU(110ohm)
output to connect to an existing Digital to Analog Converters(DAC). Trends UD
-10 USB Audio Converter's sound quality is better than the most sophisticated
high-end CD players and the retail price is only US$109.
Trends UD-10 USB audio converter plugs into the PC or Mac's USB port and lets
the users connect the computer to their Hi-Fi or Home Cinema system. As well
as offering a 3.5 mm analogue output to connect directly to the amplifier or
Trends TA-10 Class-T Stereo Audio Amplifier. Trends UD-10 also offers a choice
of optical, two electrical digital (phono and BNC) and a balanced digital output.
"Proprietary impedance matching circuits for AES/EBU (110ohm), Coaxial (75ohm)
digital outputs applies the specially designed pulse transformers for each AES/EBU
and Coaxial outputs to further isolated interference from Trends UD-10 to the external
Digital to Analog Converters(DAC). The most pure, accurate, standard digital signal
is then regenerated with minimum interference and jitter. It is a very dynamic
way to convert your computer (Desktop, Laptop etc.) to a first class CD Transport",
Trends Audio's chief designer Ricky Leung said, " With proprietary dual power
regulation circuits design (normal implementations are just directly apply the 5V
USB bus power), no matter the power is supplied from the USB bus or from external
socket, it is regulated before supply to the related ICs. The Dual regulated powers
are supplied to digital circuits and analog circuits individually".
Trends UD-10 makes the PC or Mac behave like a high-end CD Player. Trends UD-10
and PC or Mac combination provides better sound quality, larger storage capacity
and a more user-friendly interface than most standard CD players. The computer
hard disk is far superior to a CD transport, no matter the speed, stability,
error correction or jitter reduction. Audiophiles can use Trends UD-10 USB audio
converter to listen to their entire music collection from the PC or Mac, regardless
of whether they were originally downloaded on their computer or purchased on CD.
Also, it separated digital/analog ground. The digital GND (network) and the analog
GND (solid) is totally separated except connected via a ferrite bread in a single
point. It effectively reduce interference between digital signals and analog signals.
Trends UD-10 applied audiophile grade materials and electronic components, including
the high-quality precise SMD resistors and capacitors. The case of the device is
the stylish iron-gray whole aluminum one. Trends UD-10 USB Audio Converter is now
available and the suggested retail price is only US$109. For more information or
request a sample, just visit the web site at http://www.TrendsAudio.com or reach
at (852) 2566-5810 or send email at sales@TrendsAudio.com or contact the local dealer,
Please feel free to contact us if you would like to have an interview with us or
need some screen shots for this Press Release or request a FREE trial of Trends
UploadUpload
