Home > Message Board > Press Releases > Archive through 2008 > Archive through May 23, 2007 > HD-SDI Encoder Added to the TV One Product Lineup
TV One-task combats the digital era with the new high-performance 1T-C2-520 DVI, RGB, YUV to SD/HD-SDI converter which is perfect for the professional or broadcast market.
MARGATE, Kent, 10th May 2007 – The new 1T-C2-520 adds to the list of high-quality conversion devices available through the TV One-task™ product line. The 1T-C2-520 converts DVI-D 720p or 1080i HD signals to HD-SDI for broadcast or professional use. It also converts analog YPbPr or RGBHV to HD-SDI and standard analog YUV signals at 525i or 625i to SD-SDI.
Since the 1T-C2-520 doesn’t perform scaling, a chart is provided to assist in selecting the exact vertical input rates as the video source must have correct timing in order to be converted to SD/HD-SDI.
TV One’s CORIO2 technology ensures crisp picture detail when encoding takes place. A proprietary de-jitter circuit helps to optimize signal integrity even with analog video sources.
The 1T-C2-520 is housed in a Desktop metal case and an optional Single/Dual Rackmount Kit is available. It can be operated from the front panel or an RS-232 connection. An On Screen Display makes operation fast and simple.
The suggested retail price for the 1T-C2-520 is £560 (€823) and will be available in June.
The entire TV One product line can also be viewed on their website www.tvone.co.uk, alternatively you can contact their European Sales and Technical Department on +44 (0) 1843 873311 or at sales.europe@tvone.com.
UploadUpload
