Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through May 23, 2007 >
A New Realm Of Audio Now Shipping
| Posted by Michelle Suz... on Friday, May 18, 2007 - 11:11 am: |
New Brand of High-End Speakers and Amplifiers Ships Products
Oxnard, Calif, (May 18, 2007) – REALM, a new aftermarket audio company dedicated to high-end components designed for discriminating consumers, announced today it is now shipping its full line of aftermarket products. Pursuing a new standard of automotive audio, REALM will offer high-end audio components with an emphasis on sound quality.
“We are pleased to bring REALM to fruition, “said Kas Alves, vice president, sales and marketing, REALM. “Following our successful launch at CES this past January, our specialty dealers have been anxiously waiting for our product to ship. As promised, we are bringing our product to market just in time for summer sales.”
REALM components combine audiophile grade components and stringent audio testing resulting in an amplifier, subwoofer and loudspeaker offering designed to fit a consumers unique listening desires. REALM’s goal was to create an unparalleled system that provides accurate musical reproduction across the entire range.
Initially, REALM will offer a limited SKU of premier speakers, amplifiers and subwoofers. These components will only be offered through specialty retailers across the country. According to Alves, “REALM is designed to be sold to the enthusiast by enthusiasts and will only be available through REALM specialty dealers. It solidifies REALM’s commitment to quality both for the consumer and our dealers.”
REALM Amplifiers
REALM amplifiers offer tremendous power output and an extensive list of features. With mono, two and four-channel amplifiers, the REALM amplifier family are flexible and powerful enough to handle the most extreme and complex audio and visual configurations. REALM amplifiers are CEA 2006 rated and feature impressive cosmetics.
REALM is now shipping seven amplifiers that feature low impedance; adjustable high pass/low pass electronic crossover; internal Transistor Heat sinks, remote adjustable bass boost control, and built in crossover circuitry. Additional features include:
• Computer Modeled Extruded Aluminum Heat sink
• Vented End Panels with Cast Aluminum Brackets
• Illuminated Control Dials
• RCA Output
• Full Differential Inputs
• 2-Ohm Stability
• 5-way Protection Circuitry
• Intelligent Protection Indicator
• Built in Crossover Circuitry
• 0dB-12dB Variable 45Hz Bass Boost
• Remote Level Control
• Speaker level Inputs
• Built-in Maxi Fuse
• Discrete Plug Style Terminals
• Double Sided Glass Epoxy Circuit Boards
• Internal Transistor Heat sinks
• High Efficiency Multi-Stranded Power Torroids
REALM LOUDSPEAKERS
Offering the highest level of performance, REALM component loudspeakers are designed to reproduce the sound spectrum that fits an audiophile’s listening needs. REALM’s reference grade asymmetrical crossover network delivers the accuracy and clarity expected from world-class audiophile systems.
REALM loudspeakers boast high-quality materials enhancing the capabilities of the speakers and include superior components. REALM component speakers offer great low-end extension for good bass performance. REALM tweeters contain Ferro fluid that cools the voice coils and REALM mid range woofers contain phase plugs that reduce high-frequency focal point distortion. REALM loudspeakers include three-position tweeter attenuation and offer surface, flush and angle mounting hardware. Known for high-strength and light weight, REALM loudspeakers utilize a Nomex composite cone.
• Nomex Composite Cone
• Butyl Rubber Surround
• Aluminum Phase Plug
• Secure Screw Terminals
• Cast Aluminum Frame
• Universal Mounting Hole Pattern (6.75”)
• 20mm Inverted Titanium Dome Tweeter
o Ferrofluid
o Neodymium Magnet
o Surface, Flush and Angle Mounting Hardware Included
• Asymmetrical Reference Grade Crossover
o 6dB Lowpass / 12dB Highpass
o Vented, Smoked Polycarbonate Case
o Audiophile Quality Mylar Capacitors
o Large Gauge Air Core Inductors
o Aluminum Shrouded 1% Resistors
o Impedance Compensation Network
o 3 Position Tweeter Attenuation with Oversized Jumpers
o DC Voltage Tweeter Protection
Designed for smooth, balanced output and capable of handling high-powered amplifiers, REALM components offer a new choice of high-end speakers for a new level of performance.
REALM SUBWOOFERS
Any true musical representation requires tight, accurate low frequency extension.
In home audio low frequency transducers require large volume enclosures that aren’t practical in the automotive environment. REALM subwoofers are optimized for modest sized enclosures without sacrificing low extension. REALM’s uniquely designed subwoofers are able to articulate deep bass with detail and definition and reduce distortion to create a finely tuned sound for any automotive environment. REALM subwoofers are available in 10”, 12” and 15” sizes with dual 2ohm or dual 4ohm configurations.
REALM subwoofers are engineered with quality materials that offer high durability, high power handling with heat dissipation and voice coil cooling. Additional features include:
• Stitched Butyl Surround with Integrated Gasket
• High Strength IMPP Cone
• 2.5” 4-layer Dual (X)-ohm Voice Coils
• 88oz Double Stacked Magnet structure
• High Temp Aluminum Voice Coil Former
• Vented Cast Aluminum Frame
• Dual Spiders with Integrated Tinsel Leads
• Ergonomic Spring terminals
• Optimized for Small Sealed or Small Ported Enclosures
“REALM is committed to quality in the aftermarket industry,” continued Alves. “Designed for the discriminating audiophile who demands flawless sound quality in their vehicle, a new REALM in Audio has arrived.”
REALM is now available at specialty retailers across the country. Visit www.realm-audio.com for additional information.
About REALM
Introduced in 2007, REALM is committed to high-performance audio components for the automotive aftermarket. With a passion for design and emphasis on quality, REALM’s mission is to set a new standard in automotive audio. REALM develops loudspeakers, amplifiers, and subwoofers that provide accurate musical reproduction across the entire range. Visit www.realm-audio.com for additional information.
For Media Inquiries Only
Michelle Suzuki
michelle@msc-pr.com
