Home > Message Board > Press Releases > Archive through 2008 > Archive through June 08, 2007 > Take Stereo Audio the Distance with the New TV One-Task Cat 5 Extender
TV One-task has added the 1T-VGAST-CAT-XL, which is capable of sending and then
outputting the stereo audio along with the VGA signal over a distance up to 1000 feet.
MARGATE, Kent, 24th May 2007 – The popular Cat.5 series in the TV One-task™ line has added the 1T-VGAST-CAT-XL. This unit can send both stereo audio, either from a PC or microphone, and a 1280x1024 VGA resolution image to a maximum distance of 1000 feet.
The unit consists of a transmitter that takes in the Stereo Audio and VGA signal and a receiver which outputs the same Stereo Audio and VGA Signal. This makes it possible to send both signals to a remote location and maintain the Stereo Audio. A VGA loop-thru is provided and there are gain and equalization adjustments at each receiver.
The 1T-VGAST-CAT-XL has a locking DC connector and is RoHS compliant. The suggested retail price for the 1T-VGAST-CAT-XL is £279 (€410) and is available now.
For more information about TV One and their products, please visit their website www.tvone.co.uk. Alternatively you can contact their European Sales and Technical Department on +44 (0) 1843 873311 or at sales.europe@tvone.com.
