Home > Message Board > Press Releases > Archive through 2008 > Archive through June 24, 2007 > Furutech Ultimate Power 6 AC Distributor Now Available
FURUTECH DEBUTS PURE POWER 6
LUXURIOUSLY ENGINEERED POWER DISTRIBUTOR ELIMINATES EMI & RFI
ADVANCED MATERIALS AND TECHNOLOGIES ENSURES STABLE QUIET POWER FOR YOUR ENTIRE SYSTEM
Tokyo • June 18th, 2007 • Furutech Co., Ltd., manufacturer of analog and digital audio and video cable and accessories, debuts the ultimate performance Pure Power 6 AC Distributor, Pure Transmission Technology in its most preeminent form.
Luxury Build
The Pure Power 6 is built like a Swiss bank vault, a virtual black hole for EMI and RFI. The substantial, beautifully-crafted chassis is precision CNC-machined from solid aerospace-grade aluminum alloy that effectively shields against RFI (Radio Frequency Interference).
Three separate milled compartments house three independently-wired duplex receptacles using top-quality twisted-multigauge Teflon-shielded high-purity silver-plated Alpha-OFC. The hot and neutral conductor bundles from the IEC are loomed into a large, centrally-located chamber--secured Bugatti-like with eight beautifully machined rivets--that’s filled with Furutech’s EMI-absorbent Formula GC-303 material. GC-303 absorbs the high-frequency noise that develops whenever passing current through wire. This exceptional EMI-isolating material is also used in other Furutech power distributors and filters, as well as in modules surrounding all Reference III cables.
Furutech’s patented Power Plate Receptacles enhance the vault-like build, ensuring the tightest and most secure power cord fit imaginable. Pure Transmission Technology is applied at every level: The rhodium-plated receptacles are not simply flush with the outer chassis but tapped 25mm into the thick aluminum for an outstandingly tight fit.
Furutech’s already robust mounting flanges at top and bottom of each duplex outlet are held in place against the chassis with thick aluminum blocks applying pressure along the entire width of the flange rather than just securing it with screws at four points.
When Furutech say Pure Transmission, they mean it. Each duplex receptacle is additionally stabilized with double Axial Locks; a pair of special factory-torqued screws anchor the back of each receptacle at two points for ultimate mechanical integrity.
Four elegantly machined adjustable footers keeps the Power 6 stable for your system’s power cords. Run digital into one duplex, analog front-end components into another, and your amplifier on the third for stunning, unrestricted, clean, stable AC power and rich, dynamic sound.
Pure Power Grounding/Earthing Post
The three duplex receptacles are not wired to incoming ground; they “float” electrically. The green ground wire from the incoming IEC fitting is tightly fixed to the chassis at the bottom of the center chamber before it’s filled with GC-303, which further isolates the noisy ground. To ensure your safety the Power 6 must be grounded at its Grounding/Earthing Post located near the input IEC.
MSRP: $6,400
Availability: Now
THE PURE POWER 6 :: PURE TRANSMISSION TECHNOLOGY
IN ITS PREEMINENT FORM
Specifications
Chassis - CNC machined aerospace-grade aluminum alloy
AC Input/Output - 15A IEC input/3 UL-Rated duplex receptacles
Materials Processing - Metal parts treated with Alpha Cryogenic and Demagnetizing Process
Ground/Earth connection - Chassis Grounding Post
IEC - Rhodium-plated
Receptacles - 3 High Performance FP-20A ® Duplex Receptacles
Internal wiring - 3 gauges of high-quality twisted-multigauge Teflon-shielded high-purity silver-plated Alpha-OFC
Solder - Special alloy solder
Size - 8”/250mm W x 8”/250mm H x 3”/95mm D
Weight - 22lbs/10kgs
Here’s What The Critics Say
"Once it's Furutech from beginning to end, the spatial and size benefits are unmistakable. This only reiterates the underlying leitmotif of this review. Shielding from and against noise pollution in cables has become more important than ever - and Furutech has developed a very powerful yet elegant antidote it seems. Bravo."
— Srajan Ebaen, 6moons
“My first overall impression [of the Evolution cables] was one of control. …It was as though I could feel that there was something holding the music firmly within its grasp and allowing the system to reproduce more effectively the intensity, fabric and overall visceral impact that one might expect in a live environment.
“The sound I heard was simply put spectacular. The system’s ability to take the intensity of the music and blend it with the subtle nuances of particularly difficult passages allowed for a listening experience that I am somewhat unaccustomed to hearing from my system in general.
“… Extremely lifelike and palpable without being overly dominate or forward sounding. … The noise floor was lowered and I was able to hear a rich harmony of musical instruments that did not overwhelm the passage with excess noise or distortion.
“ … wholeheartedly recommend these cables to someone looking for more from their present system.”
-- Brett Rudolph, Enjoy the Music.com®
Now an International 2007 International CEA
Best of Innovations Award Winner For the deMag!
Furutech makes a wide variety of high performance 15A and 20A A/V cable and power distribution/filtering products like the e-TP4+4, e-TP609 and e-TP60 Power Distributors, and e-TP80 Power Filters, deMag Disc and Cable Demagnetizer, the Destat, a fan-driven Balanced Ion Drive device for LPs and CDS, FRD Room Diffusion Panels, PC-2 Disc Pure Cleaner, and our very special NANO Liquid Contact Enhancer, plus even more fine cable and OEM products.
Ultimate Performance • Ultimate Refinement • Ultimate Luxury
FURUTECH CO., LTD. service@furutech.com www.furutech.com
For Press Information and Photos Contact
Jonathan Scull • Scull Communications
jscull@scullcommunications.com
www.scullcommunications.com
212.807.0519
