Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through July 09, 2007 >
Panamax Expands MAX In-Wall Series With Three New Products to Improve Perform...
Panamax Expands MAX In-Wall Series With Three New Products to Improve Performance of Remote Displays
| Posted by Wall Street ... on Wednesday, June 27, 2007 - 05:08 pm: |
The new MAX In-Wall Powerkit-Pro provides a noise-free, code-compliant extension of Panamax filtration and protection to remotely located devices, such as plasma displays, LCDs, and projectors. A safer and more attractive alternative to running an unsightly extension cord from the component rack to the video output, the Powerkit-Pro accommodates optional signal line modules for a professional finish with additional EMI/RFI noise filtration built into the outlet receptacles.
Where it is not practical to run an AC line from the rack to the remote display location, the MAX In-Wall Power-Pro can utilize any branch circuit to deliver safe power to the remote display in a safety agency approved, code-compliant manner. The 15-amp Power-Pro offers two AC outlets with Level 1 EMI/RFI noise filtration for clear, detailed images and crisp sound, while thermal fusing, overvoltage protection, and catastrophic surge circuitry protect sensitive home theater components from damaging power surges and voltage transients.
The MAX In-Wall Dual Signal Bay offers an elegant, convenient solution for connecting signal lines from the source device to the display device when running cables within walls. The Dual Signal Bay accommodates two blank module inserts with pass-through plugs or two In-Wall signal protection modules and fits into many two-gang outlet brackets. The unit features a full metal housing and enlarged faceplate to accommodate oversize wall cutouts and a 14-AWG solid-wire connection for bonding/grounding to In-Wall AC units.
The Powerkit-Pro will be available at an SRP of $299.95, the Power-Pro at an SRP of $99.95, and the Dual Signal Bay at an SRP of $29.95.
Panamax ~ Furman
Panamax and Furman Sound have been international leaders in providing award-winning, innovative power management products for more than 30 years. Their products give audio/video systems the pure, noise-free power they need for superlative performance, while protecting them from damage caused by power surges and lightning. Together as part of Panamax, Inc., these two brands address all major electronic markets, including home theater, professional audio and music, broadcasting, audio/video recording, OEM, and office equipment. The companies are based in Petaluma, Calif., and sell through an international dealer network and select retail outlets. More information is available at www.furmansound.com and www.panamax.com.
All trademarks appearing herein are the property of their respective owners.
