Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through July 09, 2007 >
Atlantic Technology 6200e THX-Ultra2 Home Theater Speaker System Announced
| Posted by Admin on Thursday, June 28, 2007 - 09:29 pm: |
Atlantic Technology has redesigned its popular System 6200 home theater speaker line with improved cabinets, pared configuration options, and lower prices, while adding THX-Ultra2 certification. The new System 6200e line does away with optional side panels and pedestal subwoofers while offering a range of more flexible configuration options suitable to any home theater or multichannel audio installation.
"This system is a classic Atlantic Technology evolution: better looks, better performance, at a lower price," commented Atlantic Technology Director of Marketing Steve Feinstein. "The redesign has actually exceeded even our high expectations, and the new system looks better, is easier to specify and install, and costs less than the already-impressive original 6200 line. On top of all that, the LR and center channel speakers achieve a level of performance that meets THX's elite Ultra2 performance standards - the highest certification level available for a multichannel speaker system."
Like its predecessor, the System 6200e offers much of the industry-leading performance of Atlantic's flagship System 8200e speaker line in a smaller form factor and at a lower price point. The 6200e LR and 6200e C speakers now feature conventional permanently attached side panels in a satin black finish, eliminating the confusion in stocking and selling the previously optional cabinet panels. Additionally, the System 6200's original pedestal subwoofer systems have been replaced by the company's more traditional box-style THX Certified 642e SB subwoofers, which meet their spec effortlessly and in a configuration preferred by most dealers and consumers.
Atlantic Technology's 6200e LR floor-standing loudspeaker, and 6200 C horizontal center channel speakers are each two-way designs that are ideally timbre-matched for a coherent, seamless sound stage. Each speaker includes a sophisticated set of acoustic controls to tune performance for a variety of rooms and placement options, including High Frequency Energy adjustment for acoustically bright or dull rooms, a Location control to compensate for the acoustic effects of a pull-down screen, and a Boundary Compensation toggle that adjusts speaker output to compensate for placement near a wall or within a cabinet.
The Atlantic Technology System 6200e has been designed to integrate ideally with Atlantic's THX Certified system 4200e dipole surround speakers, delivering a completely convincing surround field. The system is available in a wide range of configurations for home theater multichannel surround installations. Retail prices begin at $6,500 for a 5.1-channel system.
From its inception in 1989, Atlantic Technology's mission has been to produce home entertainment products that exemplify the very best in both performance and value. The company specializes in complete high-performance multi-channel speaker systems, state-of-the-art home theater electronics components, and products for custom audio/video installation. For more information on Atlantic Technology and its many fine products for home theater and custom audio/video installation, visit www.atlantictechnology.com or call 781-762-6300.
Atlantic Technology System 6200e Specifications
| Model | 6200e LR | 6200e C | 4200e SR |
| Type: | Sealed-box 2-way D'Appolito array | Sealed-box 2-way D'Appolito array | Sealed-box Dipole/Bipole surround |
| Woofer | (2) 6.5" GLH | 2) 6.5" GLH | (2) 4 1/2" GLH |
| Tweeter | (1) 1" silk dome | (1) 1" silk dome | (2) 1" silk dome |
| Frequency Response | 50Hz - 20kHz ±2dB | 50Hz - 20kHz ±2dB | 80Hz - 20kHz ±3dB |
| Nominal Impedance | 6Ω | 6Ω | 8Ω |
| Crossover Frequency | 2.5kHz | 2.5kHz | 3kHz |
| Crossover Type | Computer designed Butterworth 4th order asymmetrical (time-aligned) Linkwitz-Riley | ||
| Sensitivity | 90dB | 90dB | 90dB |
| Recommended Amplifier Power Rating | 15 – 150 watts RMS | 15 - 150 watts RMS | 10 - 150 watts RMS |
| Magnetic Shielding | Yes | Yes | No |
| Dimensions w/ grilles | 7.8 x 23.5 x 14.3in | 22.5 x 11.1 x 11.5in | 10.9 x 12.4 x 7.5in |
| (W x H x D) | 194 x 584 x 356mm | 560 x 276 x 285mm | 277 x 315 x 191mm |
| Weight (ea) | 26 lbs; 11.8kg | 25 lbs; 11.3kg | 20 lbs; 9.1kg |
Model 642e SB
| Type/Features | -Powered subwoofer, sealed enclosure |
| -High efficiency tracking amplifier | |
| -2-inch, four layer vented aluminum voice coil, vented motor | |
| -Continuous 40-140Hz crossover, 18dB/octave low pass output | |
| -Variable low level stereo inputs and low level outputs | |
| -Absolute phase invert switch | |
| -Auto signal sensing on/off/bypass | |
| Bass Driver | 12" long-throw composite cone |
| Output Power | 300 watts RMS |
| Distortion (amplifier) | < 0.5% |
| Frequency Response | 25Hz - 300Hz ±3 dB |
| Peak Output | 105dB SPL into 2000 cubic Feet |
| Dimensions (WxHxD) | 19 x 21 x 20.5in; 483 x 534 x 521mm (Depth w/grille) |
| Weight | 65lbs/29.5kg |
| Power Requirements | 110V AC 50/60Hz; 240V AC 50/60Hz |
