Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through July 28, 2007 >
Defragmenting Databases. Myth or Real-McCoy?
| Posted by Colleen Toum... on Thursday, July 12, 2007 - 02:22 am: |
External fragmentation refers to the fragmentation of files on your server's disks, which can cause as much, if not more, unnecessary I/O activity as internal fragmentation. Database servers are made up of large database and log files that are pre-allocated in size at the point of their creation. If there is enough contiguous empty space on disk when the original files are created then they will not be fragmented. However, if there is not enough contiguous empty space on the disk then these original database and log files will be fragmented and spread across the empty space on your disk.
Even if the original database and log files are not fragmented when they are first created, they will almost certainly become fragmented as the database grows over time and the unnecessary I/O activity to read the fragmented database and log files hurts SQL Server's overall performance.
To defrag external fragmentation takes an operating system utility, not a SQL Server utility. When the fragmentation tool runs, it does not restructure internal contents of the file, unlike DBCC REINDEX.
After the database and log files are defragmented, the defragmented files will be a contiguous bit for bit duplicate of the original. Therefore, any holes within the database pages are still present and you will still need, from time to time, to rebuild your indexes to combat internal fragmentation.
File defrag is not going to solve all DB-optimization requirements, but it is often lesser-known piece in the puzzle. So the next time your colleague suggest that your database server does not need a defragmenter, think again.
