Home > Message Board > Press Releases > Archive through 2008 > Archive through July 28, 2007 > BreatheAudio™ introduces New Elevate 6.6 System
June 27, 2007, Hebron, KY – BreatheAudio, manufacturer of high quality, high fidelity whole home audio systems is pleased to introduce its new Elevate 6.6 Whole Home Audio System. The Elevate 6.6 has brought together a unique mix of features specially designed to address the specific needs of installers that are looking for simple installation to support the demands that the emerging production home market requires, and provides a price structure that meets this market as well.
Elevate 6.6 is rich with features, despite its very competitive price point of $1599 M.S.R.P., which include the following: 6 audio sources, sent to 6 rooms in the home, which are easily expandable to 12. 40 watts of power per zone produce high-quality, full high fidelity sound. Amazing Allport™ connection hub cuts installation time to a minimum with no guesswork to worry about. Final installation is instantaneous with very simple plug and play features. RS-232 serial port allows for easy home-automation integration. System has Philips Class D digital amplification, which provides higher output, cooler operation and prolonged life of the system. Built-in IR pass-through at keypad controls source components and offers quick and easy wireless control; specially designed to block interference from sunlight, plasma and fluorescent lighting. Fixed and variable outputs are provided on zones 1 through 4 to use with higher-powered external amplifiers (BA-200, Pulse 200-watt amplifier, sold separately) when greater output is required to larger living areas or outdoors spaces. Simple, easy to use keypad programming lets homeowner adjust bass, treble, source grouping, party mode and volume reset, with effortless two-button presses at any keypad in the house.
“The Elevate 6.6 System's value is unbeatable when you consider its feature content, performance, flexibility, and the fact that it ships complete”, says Joe Finelli, VP of Sales, BreatheAudio. “It’s the BEST value 6 Source/6 Zone System available out there. And by the way, it sounds GREAT and is a synch to install.”
The BreatheAudio Elevate 6.6 system has brought together an optimum feature set with the richest quality, high fidelity sound bundling it all into a complete package that is perfectly suited to installers that are new to the industry, or that need a solution that meets the demands for quick and easy installation that the production home market requires. Elevate 6.6 is the answer hands down.
About BreatheAudio™
BreatheAudio is a wholly owned division and unique brand identity of NuVo Technologies. BreatheAudio provides optimum quality products, leveraging it’s engineering and manufacturing expertise for the continued development of innovative technology solutions, to best serve its distribution and retail customers. It prides itself on building high quality products that are finally affordable to the masses. BreatheAudio is headquartered in Cincinnati, OH area, and manufactures in mainland China. To see more details of BreatheAudio products go to www.breatheaudio.com. For all press inquiries, please contact Trudi Luebberst at (859) 817-7227 Email: pressroom@breatheaudio.com
