Home > Message Board > Press Releases > Archive through 2008 > Archive through July 28, 2007 > Bryston Introduces Hand Assembled BCD-1 Audiophile CD Player
Peterborough, Ontario August, 2007 —Bryston (www.bryston.ca) has announced the introduction of an audiophile Redbook CD player called the BCD-1. The design emphasis of the BCD-1 has been placed on exceptional build quality and outstanding sonic performance using fully discrete Class-A analog circuitry and a 192K/24Bit Crystal DAC. "We decided to build a REDBOOK-only CD player and I can hardly believe the response—customers are calling to tell me that the BCD-1 is the best sounding CD player they have ever heard," commented Bryston's James Tanner. I think it also indicates that consumers are tired of uncertain new formats and just want a state of the art player for the thousands of CD's they already own."
Digital design: Within the digital domain, bit timing errors (called jitter) have been eliminated by perfectly synchronizing the player’s master clock and drive. The Crystal CS4398 DAC is an advanced generation chip using a combination of several different conversion methods to optimize the processing. Each premium DAC boasts dedicated power supplies—a separate, closely regulated and filtered digital power supply as well as a heavily regulated and filtered analog power supply with carefully routed electrical grounds. Finally, careful trace routing throughout the complete circuit architecture of the BCD-1 eliminates potential noise via capacitive coupling, which delivers those critical extra dB’s of noise and distortion reduction marking only the most outstanding equipment.
Discreet advantages: The Bryston BCD-1 CD Player uses discreet operational amplifiers after the DAC instead of the commonly used integrated circuits. The use of discrete devices enables Bryston engineers to exactly match the needs of the DAC and allow for a more robust output than IC-based amplifiers. The use of discrete devices also allows Bryston to select components with carefully matched input and output impedances based on specific in-circuit requirements.
Hand assembled with care: The BCD-1, like all Bryston products, is hand assembled and individually tested before leaving the factory. The BCD-1 is backed by a three year parts and labor warranty and has a US MSRP of $2395.00.
BCD-1 FEATURES:
• Redbook CD and CDR playback
• Fully Discrete Bryston Class A analog output stage
• Crystal 192k/24bit DAC
• Over-sampling is 128 times
• Independent Analog and Digital power supplies
• Balanced XLR and Unbalanced RCA Stereo outputs.
• Transformer coupled SPDIF and AES EBU Digital outputs
• Optical output
• RS-232 software upgrade
• Remote 12 Volt Trigger
• Full function IR remote control
• CD remote operates other Bryston products volume up/down/mute
• Cosmetically matches C-Series BP26/MPS2
SECIFICATIONS:
• Frequency Response - 20 Hz - 20 KHz - .2 DB
• Signal to Noise - 115 DB (un-weighted)
• THD plus Noise - .002%
• Jitter is - Negligible (below the residual of the Audio precision AP2700 test gear)
• Output Level - 2.3V Unbalanced - 4.6V Balanced
• Shipping Weight - 18 Lbs / 8.2 Kg
• Dimensions - 17 or 19 w / 11.25 d / 3.125 h inches
43.2 or 48.3 w / 28.6 d / 7.9 h cm
About Bryston: Bryston (www.bryston.ca) first opened for business in 1962 as a manufacturer of blood analysis equipment, and was named (as an acronym) for its three founders, Tony Bower, Stan Rybb, and John Stoneborough. In 1968, NASA engineer John Russell, Sr. relocated himself and his family to Canada from the US and bought the company, where his son Chris set to work designing the first Bryston amplifier. The Pro 3 made its debut in 1973, and since that time, Bryston components have become legendary for their hand-assembled build quality, performance and reliability in both the pro audio and consumer audio market segments. Bryston amplifiers are utilized in some of the world’s most renowned recording studios and owned by many discerning music industry professionals. Bryston applies manufacturing techniques and materials in the everyday assembly of their electronic equipment that are more typically utilized by the military and aerospace industries. Bryston is now based in Peterborough, Ontario Canada, just northeast of Toronto, and sold through over 150 dealers in North America and 60 countries worldwide.
