Home > Message Board > Press Releases > Archive through 2008 > Archive through August 10, 2007 > Simicomm Releases Beta of 15 Minute VoIP System
Madison, WI – July 31, 2007 – Born to remove the complexity of VoIP solutions, Simicomm™ today announced EasySpeak PBX, a software-based phone management system. This complete plug-and-play VoIP PBX provides a low-cost alternative to small to medium businesses. The EasySpeak software can be completely installed, including fully automated phone configuration, in only 15 minutes!
The solution is designed for enterprises without the technical abilities to implement or maintain phone systems. It provides resellers with a low cost, reliable solution for companies looking to migrate slowly into a VoIP infrastructure. Based on the Asterisk open source PBX, EasySpeak works with both VoIP and analog phones. A novice-tested, web-based toolbox enables simple configuration and management.
“We recognize there are many solutions targeting small businesses,” noted Dennis Barnum, CEO of Simicomm. “Our goal was to create something that removes the complexity for a non-technical audience and make it affordable.”
EasySpeak PBX (300 MB file) is downloaded from www.simicomm.com, and burned to a CD. The CD is loaded onto a (dedicated) server, which will run through the installation steps automatically. Just plug the phones and Internet into the Ethernet ports (1 and 0 respectively) and you’re ready to go. To use analog phones, a line card (i.e. Digium analog telephony devices) is required. Telephones will automatically register and be assigned extensions in the order they are connected. Changing of extensions and management of other features can be made by logging into the web-based toolbox.
EasySpeak PBX contains the features of the high-end solutions, including: Auto Attendant, Web Access to Voicemail, Music-on-Hold, Blind Transfer, T-38 Fax support, Call Forward/Forward on Busy, Call Parking, Call Queuing, Call Routing (DID & ANI), Call Transfer, Call Waiting, Caller ID, Caller ID Blocking, Caller ID on Call Waiting, Roaming Extensions, Assisted Transfer, Three-way Calling and high-end Voicemail functionality.
A free 14-day trial of EasySpeak is available through www.simicomm.com for a limited time.
About Simicomm
Simicomm is a telecommunications software company focused on providing hassle free VoIP solutions for small and medium sized businesses. Based in Madison, Wisconsin, Simicomm is the creator of the EasySpeak 15-minute VoIP phone system. Please visit www.simicomm.com for additional information.
Contact:
Michael Becce
MRB Public Relations
732-758-1100x104
mbecce@mrb-pr.com
Simicomm and the Simicomm logo are trademarks of Simicomm, LLC. Asterisk and Digium are registered trademark of Digium, Inc.
