Home > Message Board > Press Releases > Archive through 2008 > Archive through August 28, 2007 > DVI to HD-SDI Conversion – TV One makes things Simple!
The new 1T-C2-520 adds to the list of high-quality conversion devices available through the TV One-task™ product line. The 1T-C2-520 converts DVI-D 720p or 1080i HD signals to HD-SDI for broadcast or professional use. It also converts analog YPbPr or RGBHV to HD-SDI and standard analog YUV signals at 525i or 625i to SD-SDI.
Since the 1T-C2-520 doesn’t perform scaling, a chart is provided to assist in selecting the exact vertical input rates as the video source must have correct timing in order to be converted to SD/HD-SDI. By not scaling the image, frame rate conversion is avoided, thus preventing motion artifacts and video delays.
TV One’s CORIO2 technology ensures crisp picture detail when encoding takes place. A proprietary de-jitter circuit helps to optimize signal integrity even with analog video sources.
The 1T-C2-520 is housed in a Desktop metal case and an optional Single/Dual Rackmount Kit is available. This easy to use product can be operated from the front panel or an RS-232 connection and an On Screen Display makes operation fast and simple.
The new 1T-C2-520 along with many other exciting products from TV One, will be on demonstration and display at the IBC 2007 Exhibition being held in Amsterdam between 7th and 11th September, so come along to our Stand 3.437 and see it in action.
Details of this exhibition and how to register for free can be found on the TV One website www.tvone.co.uk.Upload
