Home > Message Board > Press Releases > Archive through 2008 > Archive through August 28, 2007 > TV One Releases Inexpensive Product that Scales PC and HD
The TV One-task 1T-PCDVI-PCDVI is a high-bandwidth, professional video scaler that takes PC, HD Component and DVI signals and scales them to a DVI or PC output of 1080p/WUXGA.
TV One-Task’s new 1T-PCDVI-PCDVI Video Scaler is a high bandwidth, professional PC/Component/DVI to Digital DVI scaler that accepts PC generated RGB signals (up to WUXGA), HD Component signals (480i up to 1080p) and DVI signals (up to WUXGA) and scales them to a DVI or PC output of 1080p/WUXGA. The product is now available and has a retail price of £298 (€438)
The inputs of the 1T-PCDVI-PCDVI are DVI plus Analog PC or HDTV in the formats of RGBHV, YPbPr, YCbCr and the outputs consist of digital DVI plus PC/HD. Outputs are 480i through 1080p or VGA to WUXGA. Dual, high quality scaling engines are utilized with 8-bit triple-ADC Phase Locked Loops. An integrated DVI/HDCP compliant receiver is central to the processor along with 3-D motion adaptive de-interlacers. The 3:2 pull-down, 2:2 pull-down detection/recovery and 3-D noise reduction complete the superior video signal processing capability.
The unit is easy to operate from the front panel switch matrix or via the supplied Infrared Remote Control. An On-Screen display is also provided for fast set-up. The 1T-PCDVI-PCDVI comes with a two year parts and labor warranty and comes fully equipped with cables.
For more information regarding this unit or any of the TV One product range, please see their website www.tvone.co.uk. Alternatively you can contact their European Sales and Technical Department on +44 (0) 1843 873311 or at sales.europe@tvone.com.
