Home > Message Board > Press Releases > Archive through 2008 > Archive through August 28, 2007 > Burmester B30, B25 and B20 Loudspeakers Announced
B25
The B20, B25 and B30 Speakers Boast Air Motion Transformer Tweeters, Kevlar Midrange Drivers, Powerful Oval Woofers, Superb Build Quality and Other Reference-Level Features Ideal for Home Theater and Two-Channel Listening
Burmester US, a division of Burmester Audiosysteme, Germany's leading manufacturer of high-performance electronics and speakers, introduces a series of three slim, esthetically appealing speakers capable of filling even large rooms with a full, warm sound, at CEDIA EXPO '07.
The new B30, B25 (pictured above), B20 Loudspeakers are ideal for Home Theaters or just listening to music. All are three-way, full-range, floorstanding models capable of reproducing all octaves down to the deepest bass foundation without losing a sense of naturalness and tonal balance, even at low listening levels. In performance, music reproduced by the speakers seems to float from a cloud rather than emanate from the speakers' cabinets. Built with exceptional attention to detail, every driver is burnt in a full 14 days before it's measured and computer-matched in pairs at tolerances so low as to have been thought impossible.
As in the B100, a new air motion transformer with an extended frequency range of 2,700 - 45,000 Hz is mounted in a small horn in each of the new speakers for a highly efficient, very dynamic, high-frequency resolution. A side-firing oval woofer maximizes the cone surface, while conforming to the speakers' slim design, and a powerful Ferrite magnet system enables the speakers to reproduce strong bass at a very high SPL.
Rated for 250 watts, the B30 Speaker stands 43.3 inches high, 9.6 inches wide and 16.1 inches deep. It boasts a 6-3/4-inch mid-range woofer, and a powerful 12 x 8-1/4-inch side-firing oval woofer. The speaker is rated for sensitivity at 89 db, and has an impedance of 4 Ohms.
Rated for 200 watts, the B25 Speaker stands 35.6 inches high, 7.9 inches wide and 13.8 inches deep. It features a 5-inch mid-range woofer, and an 8-1/4 x 6-1/4-inch side-firing oval woofer. The speaker is rated for sensitivity at 89 db, and has an impedance of 4 Ohms.
The B20 Speaker, rated for 150 watts, stands 34.6 inches high, 6.5 inches wide and 11 inches deep. It features a 4-inch mid-range woofer, and an 8-1/4 x 6-1/4-inch side-firing oval woofer. The speaker is rated for sensitivity at 88 db, and has an impedance of 4 Ohms.
The speakers' cabinets are made in Denmark with fine Danish craftsmanship, employing a composite of HDF and birch plywood. Each is available in a choice of Macassar ebony, Silver or Elsberry (comparable to Swiss pear) finishes for a luxurious final touch.
Burmester's new B30, B25 and B20 Speakers will be available in October, September and November, respectively; at suggested prices, also respectively, of $12,995, $9,995 and $6,995. They can be seen with the company's other outstanding products at the at the Hilton Garden Inn Downtown, 1400 Welton Street (2 blocks from the Colorado Convention Center), during CEDIA EXPO.
About Burmester US
Burmester US is a wholly owned operation of Burmester Audiosysteme GMBH, Germany's leader in high-end audio and one of the most respected names among manufacturers of high-quality stereo and Home Theater systems worldwide. Burmester's product line goes back 30 years. Today, product lines include the moderately priced Rondo Line, the ambitious Classic Line, the Top Line (suiting listeners' highest needs), and the no-compromise Reference Line. These lines include pre- amplifiers and power amplifiers, multi-channel amplifiers, integrated amplifiers, CD and DVD players, surround sound processors, FM tuners, power conditioners, speakers, and accessories for both two-channel and multi-channel Home Theater systems. Burmester offerings vary in price but never in their dedication to quality and musical performance at the highest level. All Burmester components fulfill the most stringent demands with respect to sound quality, reliability and ease of use, and all are beautifully, elegantly finished.
Burmester is also the appointed, exclusive partner for Bugatti to supply the sound systems for the $1.4-Million Veyron 16.4.
For further technical information, visit www.burmester.de, or call Burmester US at 877-287-6310.
