Home > Message Board > Press Releases > Archive through 2008 > Archive through September 05, 2007 > Infinity Introduces Its First-Ever Wireless Subwoofer At CEDIA 2007
6 September 2007
FOR IMMEDIATE RELEASE
WOODBURY, NY – Expanding its product line into the wireless subwoofer category, Infinity Systems today announced the introduction of its PS212W, a high-performance subwoofer that combines superlative low-frequency capability with the flexibility of wireless connectivity.
The PS212W simplifies subwoofer installation. Its wireless capability eliminates the need to route wires to the subwoofer through walls or under floors – a solution that provides far greater installation flexibility and more placement options in home theater and music systems.
The PS212W powered subwoofer includes a compact, easy-to-use transmitter/receiver module that operates in the 2.4GHz frequency range and offers a choice of four selectable channels to ensure interference-free operation. The module connects to an audio/video receiver (or other audio source) and sends signals to a wireless transceiver unit built into the subwoofer.
The subwoofer includes a built-in 400-watt amplifier and a 12-inch woofer featuring proprietary Infinity® Metal Matrix Diaphragm™ (MMD®) driver material, which is manufactured by anodizing both sides of an aluminum core to a controlled thickness. This process produces a low-mass, highly rigid driver diaphragm that operates with greatly reduced distortion and delivers exceptional articulation and resolution.
The PS212W features continuously variable crossover frequency and level controls and a phase switch to optimize its bass performance in any system and room; it also includes line-level and LFE inputs, enabling its use as a conventional wired subwoofer if desired. The PS212W is also ideal for use with Infinity in-wall and in-ceiling speakers, or to add authoritative, extended low-frequency capability to any home entertainment system. The PS212W has a black-ash finish accented by a black curved grille that perfectly matches Infinity Primus® Series loudspeakers.
The Infinity PS212W wireless powered subwoofer will be available in January 2008 at a suggested
retail price of $679.
The Harman Consumer Group (HCG), Inc., is a leading designer, manufacturer and marketer of a wide range of high-fidelity loudspeakers, audio and video components, and multimedia systems for use in homes and automobiles, and with computers. The group’s brands include JBL®, Infinity®, Harman Kardon®, Mark Levinson®, Revel®, Audioaccess® and Lexicon®.
HCG is a division of Harman International Industries, Incorporated. Harman International (www.harman.com) is a leading manufacturer of high-quality, high-fidelity audio products and electronic systems for the automotive, consumer and professional markets. The company’s stock is traded on the New York Stock Exchange under the symbol “HAR.”
For additional information, contact:
Frank Doris
FM Public Relations
631-385-1304 ext. 402
frank.doris@fm-group.net
Infinity, MMD, Infinity Primus, JBL, Harman Kardon, Mark Levinson, Revel, Audioaccess and Lexicon are registered trademarks, and Metal Matrix Diaphragm is a trademark, of Harman International Industries, Incorporated.
© 2007 Harman International Industries, Incorporated. All rights reserved.
