Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through September 11, 2007 >
Sonance Introduces Bandpass Subwoofer System
| Posted by Nicoll Publi... on Thursday, September 06, 2007 - 04:02 pm: |
The Sonance Architectural Series BPS-1 Bandpass Subwoofer System is designed to add deep, powerful bass impact while the enclosure remains completely hidden from view. It delivers its bass energy through a Sonance Architectural Series Finish Component that is a visually discrete complement to the surrounding architecture space.
The trimless and truly flush-mount installation mounts the plane of the subwoofer grille perfectly aligned with the plane of the wall or ceiling. Adaptor Baffles are available which allow the BPS-1 Subwoofer to be used with any size round or square Architectural Series Panel Bracket (even 4-inch) to match other AS speakers in the audio system and any separately available Architectural Series Finish Component: metal (with or without trim) or cloth (with or without trim).
Sonance recommends the use of the Sonamp® A150 power amplifier which delivers 150 watts of power RMS and provides flexible connections.
Availability: January 2008
Manufacturers Retail Prices:
BPS-1 $1050.00
Sonamp A150 $550.00
