Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through September 11, 2007 >
Sonance Adds Innovative, Easy-Install, High-Performance Surface Mount Speaker
| Posted by Nicoll Publi... on Thursday, September 06, 2007 - 04:05 pm: |
The Sonance Flair speaker applies a great deal of fresh thinking to a familiar installation challenge, beginning with its entirely unique mounting system. A simple, round steel mounting plate that accepts conventional speaker wiring is affixed to a standard ceiling “J-box,” via two supplied screws. The speaker itself is then set in place below it—and is instantly and firmly held in place by a ring of powerful neodymium
magnets inset into the speaker’s upper surface. Signal connection is automatically made between two male terminals integrated into the speaker and corresponding swiveling females in the mounting-plate—consequently, after being set in place the Sonance Flair speakers can be rotated through 90 degrees to align it to room surfaces, lighting fixtures, or designer preference.
Of course, Sonance endowed its new surface mount design with much more than just a clever mounting system. The speaker features a coaxial duo of a 5-1/4-inch carbon-fiber cone mid/woofer with a 1-inch Ferrofluid™-cooled silk-dome tweeter. The combination produces unexpectedly full-range, musically balanced sound, with outstandingly smooth, broad coverage that delivers natural stereo imaging to a wide range of listening positions, even when less-than-ideal mounting locations are dictated. (This also makes the speaker an excellent choice for surround- and rear-channel use in multichannel home-theater layouts.) The speaker’s excellent dispersion comes thanks both to its coaxial layout, which avoids the off-axis “lobing” response changes of conventional two-way arrangements, and its dome-shaped baffle surface, which is spherically radiused to all four corners. Additionally, the speaker combines good sensitivity with substantial power-handling capability, so is compatible with a wide range of high-performance electronics, delivering unexpectedly high-end sound from a deceptively simple form that protrudes just 2-1/2 inches from the ceiling surface.
The new 10-3/4-inch-square Sonance Flair loudspeaker enclosure is formed from a dense polycarbonate that resists resonances, improving musical clarity and dialog intelligibility. It is supplied with a full-coverage, removable, paintable perforated-aluminum grille that lends a quietly elegant and unobtrusive look.
Availability: January 2008
Suggested Retail Price: $480.00
About Sonance Headquartered in San Clemente, California, Sonance was founded by Scott Struthers and Geoff Spencer, who introduced the world’s first in-wall loudspeaker system to the consumer electronics market in 1982. With distribution in 45 countries around the world, Sonance remains at the forefront of technology by offering innovative design solutions that harmoniously blend sound with designs favored by leading custom integrators, architects, interior- design professionals, and design-conscious clients throughout the world.
