Home > Message Board > Press Releases > Archive through 2008 > Archive through September 11, 2007 > New 16 Port Hub Distributes Pragmatic's PADS Technology to 4 Times More Rooms...
Santa Clara, CA – September 10, 2007 – Pragmatic Communication Systems, Inc., an industry innovator in wired and wireless systems since 1994, recently announced a new improvement for the original PADS™ system: the PH-16, a 16 output hub for audio distribution over category 5 cables.
The PH-16 receives line level stereo audio on a category 5 cable from any of the Pragmatic PADS™ PT or PTI transmitters. The PH-16 hub then distributes the line level stereo audio to the rooms while simultaneously sending power for the amplifiers on the same category 5 cable. The PH-16 feeds up to 16 rooms and can be expanded infinitely with the loop output. PH-16 is compatible with the PA-15R and PA-15KP in-wall amplifiers with rotary or keypad volume controls.
The compact design of the PH-16 is ideal for any residential or commercial distributed audio applications. It can be used along with the PADS™ system for audio transmission in schools, businesses, department stores as well as many others commercial settings. PTS-1 tube speakers can be paired with PH-16 for background music systems. The PH-16 also features numerous possibilities for residential applications including intercom systems and music distribution. PADS™ is the ideal choice for retrofit applications because it requires no rewiring but instead runs off pre-existing category 5 cables. It also works well in new construction due to its easy installation. Many optional features are available to customize the Pragmatic’s PADS™ system. In addition, the PH also comes in a smaller 4-output unit.
Pragmatic Communications Systems, Inc. is a Silicon Valley based company established in 1994 to design, develop and produce a variety of innovative and environmentally conscious products for wireless audio, video and data communications. The majority of the company's products up until 1997 were designed for industrial and commercial applications, after which Pragmatic branched into the consumer market. The success of the older products led to a strong and dynamic technology base, which helps fulfill Pragmatic’s mission to create solutions to long unresolved technical problems with designs that are both compact and energy efficient. This belief has been applied to a new generation of Pragmatic products such as PADS™, DMSTM, CATSTM, DAVES™, True MusicTM wireless hi-fi system, and True ViewTM wireless video system.
More information on the products mentioned here can be found on the Pragmatic website at http://www.pragmatic1.com
