Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through September 21, 2007 >
Furutech DFV-1 Flattens Warped LPs!
| Posted by Scull Commun... on Thursday, September 20, 2007 - 12:20 pm: |
DVF-1 Record Flattener
One-Stop, One-Button Solution For Warped Records
Right From The Oven To Your Platter!
Tokyo September 20th, 2007 Furutech Co., Ltd., manufacturer of analog and digital audio and video cable and accessories, debuts the ultimate LP flattener, the DFV-1.
Every vinyl enthusiast has records in their collection that they wish were a bit less warped. The DFV-1 is the one-stop, one-button solution to your problems! Using a carefully controlled heating and cooling cycle it flatten all your warped records, even those with only slight irregularities that still unsettle your cartridge causing mistracking.
Warps And Listening
Warps are detrimental in every way. If the arm/cartridge remains parallel to the LPs surface as when playing a flat record, VTA (Vertical Tracking Angle) remains unchanged during play. Additionally, as the arm/cartridge tracks a warp on its upside, greater pressure is placed on the stylus which changes VTF (Vertical Tracking Force) until the peak of the warp, whereupon the cartridge unloads with too little VTF on the way down the slope of the warp. This muddles the sound, changes the tonal quality, imaging and soundstage characteristics of any cartridge. A flat record tracks better with less distortion.
The DFV-1 takes up little room with its space-saving, vertical design! Improved film heating technology optimizes the entire heating and cooling cycle for a perfectly flat LP that you and your cartridge will love. Just unlock and open the DFV-1, place the LP on the spindle, close and tap a single button. An LCD keeps you informed of progress with a tone sounding when done. Right from the oven to your platter!
MSRP: $1,480.00
Available: Now
DFV-1 Specifications
Rating: 117V±10% 60Hz AC Line 2A fuse
Energy Consumption 170W (max) 35W (Norm)
Heating plate max. temp ... 65
Size: 480mm/19 W x 544mm/21.5 H x 17mm/7 D
Weight:...... .11kg/24lbs approx.
Safe Usage Environment: .. Humidity 20% - 90% (No condensation)
Manufactured for Furutech by ORB High End Systems of Japan
All metal parts treated with Furutechs α Alpha Cryogenic & Demagnetizing Process
Now an International 2007 International CEA
Best of Innovations Award Winner For the deMag!
Furutech makes a wide variety of high performance 15A and 20A A/V cable and power connectors and parts, as well as distribution/filtering products like the e-TP4+4, e-TP609 and e-TP60 Power Distributors, and e-TP80 Power Filters, deMag Disc and Cable Demagnetizer, the Destat, a fan-driven, Balanced Ion Drive device for totally eliminating static from LPs and CDs, lightweight and stylish FRD Room Diffusion Panels, PC-2 Disc Pure Cleaner, and their own very special NANO Liquid Contact Enhancer, plus even more fine cable and OEM products.
Ultimate Performance Ultimate Refinement Ultimate Luxury Ultimate Value
FURUTECH CO., LTD. service@furutech.com www.furutech.com
Press Information, Reviews and Images:
Jonathan Scull Scull Communications
jscull@scullcommunications.com
www.scullcommunications.com
212.807.0519
