Home > Message Board > Press Releases > Archive through 2008 > Archive through October 23, 2007 > Professional Tuner for Residential and Commercial Applications
Santa Clara, CA - October 19, 2007 - Pragmatic Communication Systems, Inc., an industry innovator in wired and wireless systems since 1994, recently announced another of its successes: the Display Partner™, a professional quality, integrated TV/CATV tuner, stereo preamplifier with multi-channel audio switcher and stereo power amplifier. The impressive system complements any plasma display while also providing high performance audio.
Display Partner™ fits in one small and convenient rack mount unit. Not only is it very simple to operate, highly reliable and easy to install, but it also delivers high quality audio and video at an affordable price.
With all its high quality features it is of no surprise that the Display Partner™ is the ideal choice for plasma monitors and high-end projection systems that access cable television or traditional master antenna systems. It finds numerous applications in industrial and commercial installations including corporate boardrooms and training facilities.
The tuner receives all standard VHF/UHF broadcast frequencies and standard 99-channel cable TV frequencies. The multi-channel stereo switcher can accept up to 2 additional audio signals and contains digital preamplifiers with computer-controlled volume, bass, treble, and balance controls. Display Partner™ is also manageable through standard infrared remote controls and has an auxiliary IR input port provided on the rear of the unit to connect remote IR sensors. The unit has two 24 watt high efficiency mono-block power amplifiers built-in to drive speakers with a front panel LCD to display TV channels.
Pragmatic Communications Systems, Inc. is a Silicon Valley based company established in 1994 to design, develop and produce a variety of innovative and environmentally conscious products for wireless audio, video and data communications. The majority of the company's products up until 1997 were designed for industrial and commercial applications, after which Pragmatic branched into the consumer market. The success of the older products led to a strong and dynamic technology base, which helps fulfill Pragmatic’s mission to create solutions to long unresolved technical problems with designs that are both compact and energy efficient. This belief has been applied to a new generation of Pragmatic products such as DMSTM, CATSTM, True MusicTM wireless hi-fi system, and True ViewTM wireless video system.
More information on the products mentioned here can be found on the Pragmatic website at http://www.pragmatic1.com
