Home > Message Board > Press Releases > Archive through 2008 > Archive through November 15, 2007 > TV One at ISE 2008
TV One at ISE 2008
The ISE Exhibition, held in Amsterdam between 29th and 31st January 2008, is Europe’s number one show for Professional AV and Electronic System Integration. TV One is pleased to announce that they will be showcasing some of their new products for the first time in Europe at ISE 2008.
The new C2-7310 Dual Channel 11-input Video/Audio Processor will be displayed on the TV One Stand. The C2-7000 Series Video processors from TV One are the most flexible units available and address a wide range of requirements. They provide multiple inputs (up to 17 video inputs including 8 SD/HD-SDI) as well as being feature laden. Their astounding arsenal includes Dual PIP, Seamless Switching, Multiple Conversion and Scaling, Chroma and Luma Keying, and also the fantastic new Edgeblending feature. The C2-7310 also adds the most powerful audio processing in its category, allowing the user to embed, de-embed, delay, mix, route and sample rate convert an astonishing 32 channels of Digital Stereo Audio to satisfy even the most demanding of requirements.
The Edgeblending feature available on TV One Switcher/Scalers is sure to be a big crowd pleaser at the show and with a multi-projector Edgeblend with Masks and PIPs being displayed on the stand, TV One shows how simple and cost-effective it can be to create some amazing and unusual displays.
Furthermore, the powerful CORIOflex Modular Systems will also be on demonstration throughout the entirety of ISE 2008 on the TV One stand. This unique new product range allows customers to be the true architect of their installation needs by using CORIOflex modules to construct an entire system to fit their requirements. Now users can decide the number and type of inputs and necessary features in their own purpose-built and cost-effective system that is both powerful and flexible, with inter-changeable units that can be added or removed at any time.
Along with these fantastic products, TV One will be displaying and demonstrating a huge range of its superb product line including the popular SD/HD-SDI to DVI and DVI to SD/HD-SDI converters which, like all C2 products from TV One, use the more powerful CORIO®2 Technology.
The entire TV One product line can also be viewed on their website www.tvone.co.uk, alternatively you can contact their European Sales and Technical Department on +44 (0) 1843 873311 or at sales.europe@tvone.com.Upload
