Home > Message Board > Press Releases > Archive through 2008 > Archive through November 15, 2007 > FM Modulator by Axxess Makes it Clear
HOLLY HILL, FLA., NOVEMBER 12, 2007: The Axxess FM Modulator (AFM-MOD) is a wired device that is connected directly between a vehicle’s radio and FM antenna. Since the AFM-MOD is connected directly to the radio, it is less prone to interference from outside sources and provides a cleaner signal to the radio.
The AFM-MOD is designed for use with Class II, GM-LAN, Chrysler CAN and Ford CAN vehicles in which there is no 12-volt accessory wire present in the factory radio harness. Features include:
• Automatic turn-on
• Accepts accessory input signal if desired
• Accessory 12-volt output if desired (1.8 amps maximum)
• External on/auto/off feature permits override of automatic turn-on
• Stereo RCA input
• Factory set on FM 88.1
For additional information, contact Metra Electronics toll-free: 800-221-0932, or visit www.axxessinterface.com. Call for availability.
Based in Holly Hill, FL, with offices in Long Beach, CA, Metra Electronics (www.metraonline.com) is a leader in the auto sound industry as parent company of such consumer and professional installation brands as Axxess, Raptor, Silencer, The Install Bay and Tsunami, as well as the Ethereal brand of home audio/video interconnects.
MEDIA INQUIRIES ONLY:
Denise Salvaggio
EVOK Advertising
1025 Greenwood Blvd.
Suite 175
Lake Mary, FL 32746
407-302-4416 x 401 phone
407-302-4417 fax
denise@evokad.com
-30-
