Home > Message Board > Press Releases > Archive through 2008 > Archive through November 29, 2007 > New Extension System from Gefen Splits One VGA Video Signal and Distributes I...
New Extension System from Gefen Splits One VGA Video Signal and Distributes It Up To 1000 Feet Over CAT-5 Cable
CHATSWORTH, CA – When you need to generate the same video for two displays located in a remote location, Gefen’s new 2X VGA Extender can deliver. This sender/receiver system does double duty, offering a clean split and the ability to extend two displays up to 1000 feet.
Ideal for consolidating the delivery of VGA video signals, the 2X VGA Extender allows both displays to be extended over just one CAT-5e cable.
At distances up to 1000 feet, resolutions are supported up to 1080p or 1920x1200 for computer displays, making this an effective performer for high quality digital signage and professional audio/video applications.
Designed for a simple installation, the 2X VGA Extender takes just seconds to install. The sender unit connects to the VGA source; the receiver connects to both extended displays. The system uses a 5v power supply at the sender’s location; no power is needed remotely.
Gefen’s 2X VGA Extender (MSRP: $399) is available for pre-order at www.gefen.com or through a Gefen reseller, located around the world and listed online.
2X VGA Extender
http://www.gefen.com/kvm/product.jsp?prod_id=4721
Gefen Resellers
http://www.gefen.com/dealers/worldmap.jsp
About Gefen:
Gefen delivers advanced technologies with multi-platform extension, switching, distribution and conversion capabilities. Gefen equipment is valued around the world in professional A/V, information technology and consumer electronics/home theater environments. Their add-on hardware maximizes functionality by enabling systems to operate beyond their original capabilities. A selection of high quality cabling is also available. Visit www.gefen.com for detailed product information.
