Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through December 12, 2007 >
Alpine Electronics Ships New Type-X Series Speakers
| Posted by Alpine Elect... on Tuesday, December 04, 2007 - 02:45 pm: |
ALPINE ELECTRONICS SHIPS NEW TYPE-X SERIES SPEAKERS
High-Performance Speakers Set Standard for In-Vehicle Sound Quality
TORRANCE, Calif., Dec. 4, 2007 High-performance speakers bring out the full potential of the audio system in a vehicle. Alpine Electronics of America, Inc., the industry-leading manufacturer of automotive mobile media solutions, now is shipping its highly anticipated Type-X Series speakers to do just that.
The right speakers are crucial elements for great sound, particularly for a sophisticated mobile electronics setup. Type-X speakers deliver highly accurate, precise in-vehicle sound reproduction and better music detail, pleasing even the most scrupulous of audiophiles. The speakers come in two categories: Type-X Pro and Type-X Reference, making it possible for consumers to find the high-performance speaker that best fits their needs. All Type-X speakers have woofers that use a Neodymium magnet, which results in a reduced mounting depth and diameter. This allows the speakers to fit in more vehicles while also improving their performance and accuracy.
For true sound connoisseurs, or even consumers that just want the best sounding car on the block, the Type-X speakers are the answer. These speakers sound great with any type of music, from classical to country, said Stephen Witt, vice president, marketing and product development, Alpine Electronics.
Type-X Pro
The SPX-17PRO 6.5-inch component 2-way speaker and SPX-13PRO 5.25-inch component 2-way speaker each feature a cross-rib hybrid glass fiber woofer cone, 1.25-inch ring radiator tweeter and an audiophile-grade network for detailed reproduction of all types of music. Replaceable Phase Link modules are included with each Type-X Pro set to allow easy custom-tuning for many popular speaker locations. The SPX-17PRO was recognized with a 2008 CES Innovations Design and Engineering award for the In-Vehicle Audio category.
Type-X Reference
The SPX-17REF 6.5-inch component 2-way speaker and the SPX-13REF 5.25-inch component 2-way speaker combine premium sound with an easy-to-install design. The Type-X Reference speakers come with a tweeter mounting bridge that allows users to turn the component system into a coaxial system, for greater installation flexibility.
Type-X Pro Speakers
CEA-2031 speaker ratings: 100W maximum RMS, 300W peak power handling, nominal impedance 4ohm
Frequency response: 35Hz 60kHz
Ring radiator tweeter
Availability: Now
Suggested Retail Index: $650
CEA-2031 speaker ratings: 80W maximum RMS, 240W peak power handling, nominal impedance 4ohm
Frequency response: 40Hz 60kHz
Availability: Now
Type-X Reference Speakers
CEA-2031 speaker ratings: 75W maximum RMS, 225W peak power handling, nominal impedance 4ohm
Frequency response: 35Hz 40kHz
Ring dome tweeter
Availability: Now
Suggested Retail Index: $400
CEA-2031 speaker ratings: 60W maximum RMS, 180W peak power handling, nominal impedance 4ohm
Frequency response: 40Hz 40kHz
Ring dome tweeter
Availability: Now
About Alpine Electronics
Alpine Electronics is an automotive electronics system supplier and an ISO certified global corporation. Alpine specializes in engineering and manufacturing products for mobile media systems that include audio, video, satellite-linked navigation and connectivity solutions. With research and development facilities in Asia, Europe and the U.S., Alpine is the automotive specialist for premium sound systems and vehicle navigation for both aftermarket and OEM factory installations. Alpine Electronics is a consolidated subsidiary of Alps Electric Co., Ltd., one of the worlds premier manufacturers of electronic components for computer, communications and car electronics equipment. Visit www.alpine-usa.com <http://www.alpine-usa.com/> to learn more about Alpine products or to find an authorized retailer.
Alpine Media Contacts:
Connie Sung or Jennifer Cody
WONGDOODY Communications
(310) 280-7963 or (310) 280-7717
connie.sung@wongdoody.com
jennifer.cody@wongdoody.com
