Da-Lite Adds Articulating Flat Panel Wall Mount
| Posted by Brian Schwartz on Friday, December 14, 2007 - 04:15 pm: |
Share |
Create New |
Reply
| Edit
Da-Lite Screen Company announces the addition of an Articulating Flat Panel Wall Mount, the Advance PWM-AR1. Equipped with an articulating arm, the mount can extend a flat panel monitor up to 29” away from the wall. The PWM-AR1 is designed with a unique rail mounting system to make installation simple for any plasma with mounting holes 1 ½” to 62” apart horizontally and up to 20 ½” apart vertically. The mount will hold up to 130 lbs. and features 20 degrees of tilt. The PWM-AR1 is finished with a black or gray powder coated finish and includes a five year warranty.
