Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through December 26, 2007 >
Driver Magician 3.27: device drivers backup, restoration, update and removal ...
Driver Magician 3.27: device drivers backup, restoration, update and removal utility
| Posted by Michael Lee on Tuesday, December 18, 2007 - 11:55 pm: |
A driver acts like a translator between the device and programs that use the device. Most hardware will be useless without them. Driver Magician offers a professional solution for device drivers backup, restoration, update and removal in Windows operating system. It identifies all the hardware in the system, extracts their associated drivers from the hard disk and backs them up to a location of your choice. Then when you format and reinstall/upgrade your operating system, you can restore all the "saved" drivers just as if you had the original driver diskettes in your hands. After one system reboot, your PC will be loaded and running with the required hardware drivers.
What's more, Driver Magician has a built in database of the latest drivers with the ability to go to the Internet to receive the driver updates. It saves lots of time to find the correct drivers and mature drivers will obviously increase the performance of hardware. If there are unknown devices in your PC, Driver Magician helps you detect them easily and quickly with its built in hardware identifier database.
Main Features and Benefits:
* Back up device drivers of your computer in four modes.
* Restore device drivers from backup in one mouse click.
* Update device drivers of your PC to improve system performance and stability.
* Uninstall device drivers
* Live Update device identifier database and driver update database.
* Detect unknown devices.
* Get detailed information of the hardware drivers.
* Clone all drivers to an auto-setup package (.EXE), so you can restore drivers without installing Driver Magician.
System Requirements:
* Windows 98/ME/2000/XP/Server 2003/Vista/x64
* Pentium 166MHz
* 32 MB of available RAM (64 MB recommended) plus 5 MB of available disk space for installation
Pricing and Availability:
Driver Magician may be purchased for 29.95 USD from http://www.drivermagician.com, the trial version has 15-days limitation.
