Home > Message Board > Press Releases > Archive through 2008 > Archive through January 07, 2008 > Eventus Audio USA debut at 2008 CES in Las Vegas
FOR IMMEDIATE RELEASE!
Eventus Audio will be premiering at the 2008 International CES their Lysithea ($28,000) three-way loudspeaker that utilizes an evolution of the patented Simulated Anechoic Cabinet Construction [SACC] technology. SACC is said to reduces cabinet vibration and internal reflections to eliminate unwanted cabinet-causing distortions. The overall design is similar to a large stand mounted monitor; however, in place of a stand is an elegantly designed base with a captive low frequency driver. The crossover, located outside of the cabinet in the back of the loudspeaker, is damp-mounted in order to minimize the deleterious effects of the driver vibrations and its typology comes from the Eventus Audio's Nebula. A ring radiator tweeter and 5-inch carbon fiber cone midrange and mated with a 7.5-inch carbon fiber woofer to produce frequencies from 40Hz to 45kHz. Sensitivity is 89dB/W/m, weight is a staggering 99 lbs each, and dimensions are 42 x 12 x 21.5 (HxWxD in inches).
The LYSITHEA will be presented by Eventus Audio USA, who will make its industry debut at the 2008 International CES in Las Vegas, January 7-10, in Suite 29-125 in the Venetian Hotel. Eventus Audio USA is the brainchild and latest business venture of Aldo Filippelli; Dynaudio North America founder and ex-Director. Products on display will represent some of the finest and most attractive high-end audio loudspeakers and electronics from Italy featuring Eventus Audio (loudspeakers), Audio Analogue (electronics), and Monolite Design & Technology (custom inwall/onwall and lifestyle speaker systems), all of which are exclusively distributed by Eventus Audio USA in the United States, Canada, and Caribbean. If you are attending the show, you are cordially invited to stop by and enjoy fine Italian hospitality and experience elegance.
Eventus Audio USA
1111 Essex Ct.
Batavia, IL 60510
Phone: (630) 879-6000
Website: www.eventusaudiousa.com
Email: info@eventusaudiousa.com
