Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through February 06, 2008 >
TEAC inCore Audio ZE-1000 Hi-Definition Earphones Announced
| Posted by Admin on Tuesday, February 05, 2008 - 04:46 am: |
New Sound Isolating Stereo Earphones for Quality Music Listening
TEAC America, Inc. announces the addition of TEAC inCore Audio ZE-1000, its new Hi-Definition Earphones, to its Audio Product line.
With "inCore Audio" TEAC is presenting a new set of earphones that are designed for music lovers looking for a rich and lifelike listening experience. Comfortable and stylish, inCore Audio delivers full range audio that -- due to the patented 5-layer silicone ear pads -- seal off ambient noise resulting in greater acoustic isolation.
Thanks to the dual hi-definition BA (Balanced Armature) drivers and the unique sound isolating in-ear design, inCore Audio earphones deliver a great listening experience with thrilling dynamics, yet characteristically "natural" with layers of musical textures and subtleties.
TEAC's inCore is not only designed for music lovers looking to upgrade the earphones included with their iPod or MP3 player, but it's also a perfect companion to audio fans that like to listen to their favorite CDs "on-the-go" ... or on-stage.
Not only the four integrated high performance micro-speakers contribute to the inCore's high-quality sound, the included sound isolating silicone ear pads also block ambient noise up to -30dB and assure a perfect fit and comfort. An airtight seal within the ear canals is a key to optimizing sound isolation.
From vocals to acoustic guitar to flutes to drums, the result is a more rewarding personal listening experience that can be taken anywhere, anytime. Additionally, you are no longer forced to maximize the volume, where ambient noise is high, which may save your hearing in the long run.
TEAC inCore Audio ear pads come in three sizes (S, M, L) and accommodate many different ear shapes. In addition to the sound isolating pads and modular cable, TEAC also provides a durable and compact carrying case as well as a 1/4-inch (63mm) jack for home stereo system application and an airplane adapter-plug. Being on an airplane, you will enjoy the comfort of sound isolation and noise reduction of inCore during extended wear.
Technical Data at a Glance
| Model name | ZE-1000 |
| Speaker type | Dual Balanced Armature Drivers (Two per ear piece) |
| Sensitivity | 109dB SPL/mW |
| Impedance (1kHz) | 15 ohms |
| Frequency response | 20 Hz - 20 kHz |
| Cable length | 47 in. / 1.2 m |
| Weight | 0.5 ounces / 15 g |
| Stereo plug | 1/8 in. / 3.5 mm |
About TEAC America, Inc.
TEAC America, Inc., the largest subsidiary of the Japanese electronics maker TEAC, distributes high grade audio video electronics, consumer electronics, computer data recording and storage devices, computer peripherals and professional recording equipment as well as disc publishing and duplication products. Products are marketed by TEAC America under the brand names ESOTERIC, TEAC and TASCAM. TEAC America, Inc., was established in 1967.
