Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through February 21, 2008 >
Tripp Lite Introduces Easy-Pull Cables for Custom Video Installations
| Posted by Tripp Lite on Monday, February 18, 2008 - 04:55 pm: |
FOR IMMEDIATE RELEASE
Chicago, IL (February 18, 2008)—Tripp Lite, a world-leading manufacturer of power protection and connectivity products, has introduced a new line of cables for custom video installations. Easy-Pull Cables are designed to make it easier and safer for installers to accomplish long cable runs while maintaining compliance with stringent building codes.
Easy-Pull Cables feature molded, detachable connectors and threaded end caps with integrated pull tabs. Because bulky connectors are added on after the cable is run, Easy-Pull cables can be installed through conduit and drop ceilings where conventional cables with permanently attached connectors won’t fit. The pull tabs tolerate up to 30 lbs. of pull force, while the end caps protect cable connectors from dirt and grime during pull-through. Easy-Pull Cables can be used for long cable runs in a wide range of applications, including home/business theaters, school and corporate training facilities and retail video signage.
“Easy-Pull Cables are designed specifically to meet the demanding requirements of professional-grade video installations,” said Tripp Lite Cables and Connectivity Product Manager David Posner. “Because the connectors are detachable, the cables can be pulled through conduit as small as three-quarters of an inch in diameter. By using Easy-Pull in place of conventional video cables, installers can save time and money on every job that requires long cable runs.”
Easy-Pull Cables are stocked in multiple lengths up to 100 feet for both analog (VGA) and digital (DVI/HDMI) applications. Custom cable lengths and plenum-rated cables are available. Extender and wall plate accessories are also available to permit DVI and HDMI cable runs of up to 150 feet. All cables, connectors and accessories are manufactured to the highest quality standards, assuring superior video performance in the completed installation. Cables and connectors are offered separately and as all-in-one-kits.
For more information on Tripp Lite’s new Easy-Pull Cables and the entire Cables & Connectivity line, go to:
http://www.tripplite.com/products/cables/Easy-Pull-index.cfm
About Tripp Lite
Outstanding product reliability and exceptional service have been Tripp Lite trademarks for more than 85 years. Tripp Lite’s innovations include the world’s first UPS system designed specifically for personal computers, and the world’s most trusted premium surge suppressor—the Isobar®—with more than 16 million in use. Tripp Lite maintains the highest level of ready-to-ship inventory in the industry with more than 1,000 different products, including UPS systems, rack systems, PDUs, PowerAlert software for enterprise-level system management and control, surge suppressors, KVM switches, cables and connectivity products, inverters, power strips, notebook accessories and more. Headquartered in Chicago, Illinois, Tripp Lite maintains a global presence with fully staffed offices worldwide. Additional information, including a list of Tripp Lite’s sales offices and authorized reseller partners, can be found by visiting Tripp Lite’s website: www.tripplite.com
Media Information
Gloria Wong - Media / Public Relations Manager
773.869.1229 / fax 773.869.1935
gloria_wong@tripplite.com
