Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through March 02, 2008 >
Sony PFR-V1 Personal Field Speakers Announced
| Posted by Admin on Tuesday, February 26, 2008 - 11:03 pm: |
Speakers Made Personal
In a marriage between headphones and speakers, the PFR-V1 personal field speakers are designed to create a listening field around your ears. Music is projected through two 1-inch, die-cast aluminum speakers that are connected with a headband made of light-weight duralumin metal. When you place the band on your head, the speakers appear to float in front of your ears. The silicone rubber fittings on the band position the speakers about a half inch from your outer ear and direct the front of the speakers toward your ear canal.
The speakers deliver mid- and high-range audio frequencies in a field of sound aimed toward the outer ear, while the bass frequency sound is delivered directly to the ear canal via the extended bass reflex ducts.
By placing the speaker unit outside the ear and delivering the audio from multiple directions, you get the sense that music is being played directly in front of you -- similar to the experience of being in a concert hall.
The PFR-V1 personal field speakers, powered by two AA batteries, will be available in April for about $500.
