Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through March 12, 2008 >
JL Audio Introduces HD Amplifiers
| Posted by Nicoll Publi... on Thursday, March 06, 2008 - 02:29 pm: |
We've mated this revolutionary core technology to our legendary R.I.P.S. power supply, advanced thermal management systems and a full complement of studio-grade processing features to put the all-new JL Audio HD amplifiers in a performance class all their own.
Of course, being Class D switching amplifiers, you can expect low current draw and a very compact chassis (and you won’t be disappointed on either front). But, what makes the HD amplifiers really special only becomes clear when you listen to one.
Single-Cycle Control: High-Fidelity Class D is a reality. (U.S. Patent #6,084,450*)
Single Cycle Control is a unique approach to controlling a full-range Class D amplifier. By tracking the audio signal, comparing it to the real PWM waveform and then correcting it in each and every cycle (over 400,000 times per second), a multitude of distortion-causing mechanisms can be tightly controlled to enable pristine amplification.
While there are certainly less expensive ways to make a full-range switching amplifier, no other Class D control system works faster or more accurately than Single Cycle
Control, which is why no other mobile audio amplifier in the world performs like a JL Audio HD.
R.I.P.S. (Regulated, Intelligent Power Supply)
Tight power supply regulation maintains rated power output and low distortion operation over a wide range of vehicle supply voltages (11V - 14.5V), while the “Intelligent” portion of the R.I.P.S. system automatically optimizes the amplifier’s output power over a wide range of load impedances (1.5 - 4 ohms per channel).
Differential-Balanced Inputs
Ensure noise-free compatibility with a wide range of signal sources, including OEM systems.
Studio-Grade Signal Processing
- Variable slope, state-variable crossover filters (12 or 24dB/octave), with fully-variable frequency selection from 50-500 Hz (both models)
- True remote level control with optional HD-RLC controller (assignable channels on HD600/4)
- HD750W/1 also features an infrasonic filter and output polarity control.
- Pass-through preamp outputs (both models)
- Security cover for all controls is included
- Oh, yes... small and efficient, too!
- 13% smaller overall and over 1/2-inch shorter in height than the leading competitor.
- Outstanding overall efficiency (80% at 1/2 rated power) allows for huge power from a tiny chassis and is kind to the vehicle’s charging system, drawing 60% less current than a Class A/B design of equal power!
- Stackable chassis design
- Security cover for controls
- Removable power and speaker plugs
- RealSink thermal management
HD750/1– 750 Watt Monoblock
Type: Class D, Full-Range Amplifier
Continuous Power:
750W x 1 @ 1.5 - 4 ohms
(11.0V-14.5V supply with <0.08% THD+N)
Dimensions: 10.75 x 7.87 x 1.93 in.
273 x 200 x 49 mm
MSRP: $699.95
Availability: 2nd Quarter, 2008
HD600/4 – 600 Watt Four-Channel
Continuous Power:
150W x 4 @ 1.5 - 4 ohms per channel
300W x 2 @ 3 - 8 ohms (bridged)
273 x 200 x 49 mm
MSRP: $799.95
Patented technology used under exclusive license for mobile audio from PowerPhysics, Inc .-Newport Beach, CA
