Home > Message Board > Press Releases > Archive through 2008 > Archive through March 12, 2008 > JL Audio Introduces G & M Series Amplifiers
Miramar, FL—March 6, 2008—JL Audio has introduced the G & M Series Amplifiers and by popular demand, the company has re-rated and renamed the A Series amplifiers for direct comparison to the rating method employed by other manufacturers.
All power ratings for the new G-Series and 2008 M-Series Marine Audio amplifiers are based on the “industry standard” rating method (14.4V supply voltage with less than 1% THD+N, all channels driven).
All the goodness of JL Audio amplification has been left intact. The differential-balanced inputs, killer signal processing features, JL Audio’s unique “never quit” rollback protection circuit, and our super-clean, patented amplifier circuits are still there, delivering the same quality you expect from JL Audio.
Six models are available in the G-Series:
G1300
300 Watt Monoblock Full Range Amplifier
Continuous Power @14.4V:
150W x 1 @ 4 ohm
300W x 1 @ 2 ohm
THD at Rated Power:
<1% THD, 20 Hz-20 kHz
Frequency Response:
10Hz-25 kHz (+0, -1dB)
Dimensions (L x W x H):
9.80 in. x 9.25 in. x 2.50 in
250 mm x 235 mm x 63.5 mm
MSRP: $249.00
Availability: 2nd Quarter, 2008
G1300
150W x 1 @ 4 ohm
300W x 1 @ 2 ohm
THD at Rated Power:
Frequency Response:
MSRP: $249.00
G1700
700 Watt Class D Monoblock Subwoofer Amplifier
Continuous power @ 14.4V:
350W x 1 @ 4 ohm
700W x 1 @ 2 ohm
THD at Rated Power:
<1% THD, 20 Hz – 250Hz (+0, -1dB)
Dimensions: (L x W x H):
11.81 in. x 9.25 in. x 2.50 in.
300 mm x 235 mm x 63.5 mm
MSRP: $429.95
G-MAX
1200 Watt Class D Monoblock Sub Amplifier
Continuous Power @ 14.4 V:
600W x 1 @ 4 ohm
1200 W x 1 @ 2 ohm
THD at Rated Power:
<1% THD, 20 Hz-250 Hz
Frequency Response:
10 Hz – 250 Hz (+0, -1 dB)
15.75 in. x 9.25 in. x 2.50 in.
400 mm x 235 mm x 63.5 mm
MSRP: $599.95
G4500
500 Watt Four-Channel Amplifier
80W x 4 @ 4 ohm per ch.
125W x 4 @ 2 ohm per ch.
THD at Rated Power:
<1% THD, 20 Hz – 20 kHz
Frequency Response:
10 Hz – 25 kHz (+0, - 1dB)
13.80 in. x 9.25 in. x 2.50 in.
350 mm x 235 mm x 63.5 mm
MSRP: $369.95
Availability: 2nd Quarter 2008
G2250
250 Watt Two-Channel Amplifier
Continuous Power @ 14.4V:
80W x 2 @ 4 ohm per ch.
125W x 2 @ 2 ohm per ch.
THD at Rated Power:
<1% THD , 20 Hz – 20 kHz
Frequency Response:
Dimensions: L x W x H):
9.80 in. x 9.25 in. x 2.50 in.
MSRP: $249.95
G6600
600 Watt Six-Channel Amplifier
75 W x 6 @ 4 ohm per ch.
100W x 6 @ 2 ohm per ch.
THD at Rated Power:
Frequency Response:
10 Hz – 25 kHz (+0, -1 dB)
17.70 in. x 9.25 in. x 2.50 in.
450 mm x 235 mm x 63.5 mm
MSRP: $489.95
M-Series Marine Audio Amplifiers:
M2250
250 Watt Two-Channel Marine Amplifier
THD at Rated Power:
Frequency Resonse:
MSRP: $269.95
M6600
600 Watt Six-Channel Marine Amplifier
75W x 6 @ 4 ohm per ch.
THD at Rated Power:
Frequency Response:
10 Hz – 25 kHz (+0, -1dB)
MSRP: $539.95
M1700
700 Watt Class D Monoblock Marine
Subwoofer Amplifier
350W x 1 @ 4 ohm
700W x 1 @ 2 ohm
THD at Rated Power:
<1% THD, 20 Hz – 250 Hz
Frequency Response:
MSRP: $479.95
M4500
500 Watt Four-Channel Marine Amplifier
80W x 4 @ 4 ohm per ch/
THD at Rated Power:
Frequency Response:
MSRP: $409.95
