Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through March 12, 2008 >
TV One-task DVI Routing Switcher with HDCP Now Available
| Posted by Debbie Heath on Friday, March 07, 2008 - 04:31 am: |
MARGATE, Kent UK, 07th March 2008 – The TV One-task 1T-SX-524 DVI Switcher is a compact, high performance product designed to meet the most demanding requirements for the switching of DVI signals with HDCP copy protection. The 1T-SX-524 has four inputs, and it can be controlled from the front panel input selection button or the included infrared remote control. The unit has a recommended retail price of £195 (€287).
The 1T-SX-524 has a maximum pixel rate of 165 MHz and provides resolution capabilities up to 1920x1200 and 1080p. It has DVI-I connectors for the input and outputs and is powered by an included power adapter that provides 5VDC for operation. If a conflict exists with other IR remote controls in the operational environment, the included IR remote controller can be easily reprogrammed to avoid the problem.
An LED display indicates the current input selection and the presence of DC Power. An IR Remote Receiver Option is available for applications requiring the unit to be hidden from view or when it is desirable to extend the range beyond a direct view of the unit such as around a corner.
This product as well as the entire TV One product line can be viewed on their website www.tvone.eu, alternatively you can contact their European Sales and Technical Department on +44 (0) 1843 873311 or at sales.europe@tvone.com.
