Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through March 26, 2008 >
System Reliability is Always Crucial
| Posted by B. Boyers on Thursday, March 20, 2008 - 02:14 pm: |
The escalating sizes of today’s disks and files have caused file fragmentation to occur at much higher levels than past systems. Couple that with the severely increased demand on servers due to the Web, crucial CRM applications, and modern databases, and without a solution one has a recipe for disaster. On today’s servers, a fragmentation solution is mandatory.
Quite in addition to having such a solution, however, attention should be paid to the defragmentation solution as well, especially in regard to site volume and requirements. For most sites, manual defragmentation—the case-by-case launching of a defragmenter when desired or needed—is no longer an option due to fragmentation levels and time required for a defragmenter to run. For many years, defragmenters have been available with scheduling options which would allow specific times for defragmentation to be set, so that defragmentation would occur frequently enough to keep fragmentation under control and at times when impact on system resources wouldn’t be an issue.
In the last few years, however, even scheduled defragmentation is starting to become out-of-date. In addition to the extra IT time it takes to set schedules and ensure they are optimum, scheduled defragmenting is being found not to be adequate to keep up with the exponential increase in fragmentation rates. Hence, evolution of defragmentation technology that will work constantly in the background, with no impact on system resources, has begun to appear.
Reliability of today’s system, especially servers, is obviously vital. Tools such as the Windows Reliability and Performance Monitor will always be used to check and maintain system reliability. But as a standard action in maintaining system reliability, defragmentation should always be performed.
