Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through August 16, 2004 >
Now available TOTEM'S new revolutionary subwoofer....... THE TOTEM DRUM
| Posted by Nico Bruzzese on Tuesday, June 01, 2004 - 11:50 am: |
Unlike other similar systems such as "kickers" and "Shakers" that only work on one or two frequencies, the TOTEM DRUM works much like a conventional subwoofer in the sense that it emits a large range of frequencies from 150Hz down to 10Hz. This large frequency range translates to precise detailing and a "realistic" feel that is not produced by any other system.
Machined from solid Aluminium the TOTEM DRUM MODULE has a low Co drag factor that allows the Subwoofer to be extremely fast. Without large amounts of air to contend with (like conventional subwoofers) the TOTEM DRUM reproduces amazing detail at blinding speed.
Powered by it's own dedicated amplifier that is available in all of TOTEMS exotic wood finishes, The TOTEM DRUM AMPLIFIER is able to support up to two DRUM MODULES which in turn can activate up to 4 seats each.
Features:
Easily installed in any seating arrangement
Intense Low Frequency sounds and acoustic vibrations without the deafening sound level
Acoustic vibrations are isolated to the couch
Harmonically extended and correct
Compatible with all video media
Drum amplifier can operate up to two modules for added seating
Available in all TOTEM wood Finishes
Black Claws as standard issue
Drum Tube Specs:
· 100 watts RMS, 400 watts Peak
· 8 ohms
· Aluminium Cooling System, 10” x 3”
· Aluminums Tube and Cover
Drum Amplifier specs:
· Frequency response 10Hz - 150 Hz
FOR MORE INFORMATION VISIT US AT WWW.TOTEMACOUSTIC.COM
