Home > Message Board > Press Releases > Archive through 2008 > Archive through April 14, 2008 > Gefen Wireless USB Extender Liberates Digital Audio Controls for Yamaha Live ...
Gefen Wireless USB Extender Liberates Digital Audio Controls for Yamaha Live Sound Department
CHATSWORTH, CA – In order to demonstrate the portability and high value performance of its 01V96V2 Digital Mixing Console, John Schauer, product manager for the Live Sound department of Yamaha Corporation of America, selected Gefen’s Wireless USB Extender. Schauer can control the 01V96 from the USB port using both Macintosh and PC computers.
“We wanted a simple wireless solution to allow control from a distance, and without cabling,” he explained. “And the Gefen extender works great.”
The Gefen Wireless USB Extender enables data transmitted through a USB port to be delivered up to 100-feet in distance from the small sender unit to the receiver with no connection cables in between.
As the product manager for Live Sound, Schauer’s role is to work with engineers to develop solutions for Yamaha’s customers, but he also looks for compatible technologies that enhance the use of Yamaha’s products.
Initially, Schauer used the wireless extender during sales staff and dealer trainings to demonstrate how simply audio can be controlled without an intricate setup. “We wanted to avoid having a ‘snake’ cable that sends all the inputs to and from the stage to the mixer, allowing for a quicker, cleaner setup,” he said.
Demonstrations included the Yamaha 01V96 digital mixing console, a Presonus Digimax LT Microphone preamplifier/digital interface, a Dell Latitude D820 laptop and an Apple MacBook Pro.
The Gefen Wireless USB Extender was selected primarily because of its simplicity. “One of its best features is the easy setup,” said Schauer. “The solution is completely transparent, and stability and security of the wireless link has not been an issue. The connection is very robust.”
On the road installations require a robust solution that is easy to use and simple to install. Schauer also required a high degree of reliability. “It needed to function out in the world with lots of other RF interference and still retain its connectivity.”
Schauer also tested the Gefen Wireless USB Extender in a real-world environment with a local band that controls their on-stage mixer using a PC located sixty feet from the stage.
“It is a very elegant, simple solution that gives our customers the chance to operate their digital audio console from a position out in the audience without all the wiring required by conventional means,” said Schauer. “We are very satisfied with the Wireless USB Extender from Gefen, and will benefit as more of our digital mixers find their way into situations where portability, ease of setup, reliable operation and the ability to be wireless are key.”
About Gefen:
Gefen delivers advanced technologies with multi-platform extension, switching, distribution and conversion capabilities. Gefen equipment is valued around the world in professional A/V, information technology and consumer electronics/home theater environments. Their add-on hardware maximizes functionality by enabling systems to operate beyond their original capabilities. A selection of high quality cabling is also available. Visit www.gefen.com for detailed product information.
About Yamaha Corporation of America:
Yamaha Corporation of America is the largest subsidiary of Yamaha Corporation, Japan and offers a full line of musical instruments and sound reinforcement products to the U.S. market. Products include: acoustic and digital pianos, portable keyboards, guitars, acoustic and electronic drums, band and orchestral instruments, marching percussion products, synthesizers, professional digital and analog audio products, and innovative technology products targeted to the hobbyist, education, worship, professional music, and installation markets.
