Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through April 24, 2008 >
Visonik V1802A Car Amplifier Announced
| Posted by Eyad Aboabdo on Monday, April 21, 2008 - 05:08 pm: |
Aside from its exciting cosmetics, innovatively engineered and modernly sleek design, here are some of the features that make this amplifier second to none. It starts off with a double sided glass epoxy circuit board with full Mosfet circuitry and power supply, Variable low pass (50-250Hz) and high pass (50-250Hz) filters, Variable 0-18 dB bass boost, THD 0.05%, S/N ratio: 85dB, 3 way thermal, short and overload protection, and a variable 220mV – 8V RCA input voltage.
At 12.5 volts the unit will produce the following power: 2 x 300 watts RMS @4Ω stereo, 2 x 600 watts RMS @2Ω stereo, 1 x 1800 Watts Peak Power @ 4Ω mono. The amp utilizes a series of 21 Red LED’s that make it look as hot as it performs.
There are 3 other models completing this series including a mono block, a 4-channels and another 2-channel amplifier. No matter what you’re looking for, Visonik has an amplifier to fill your needs.
Check out the V1802A and Visonik’s complete line of mobile audio products at a dealer near you so you can see and feel what you’ve been missing.
For more information, you may contact Visonik at (310) 223-0400 or you may write them at 18601 S. Susana Road, Rancho Dominguez, CA 90221 or visit them on the web at www.visonikcaraudio.com
MSRP $386.00
