Home > Message Board > Press Releases > Archive through 2008 > Archive through May 20, 2008 > TV One Releases HDMI to HDMI Scaler with Audio Embedding/De-Embedding
The latest video scaler added to the TV One-task inventory is the 1T-VS-626. It can accept audio embedded in the incoming HDMI signal or from the separate Toslink or analog stereo inputs. The HDMI output can then be scaled to the same or a different resolution. Output audio is simultaneously present embedded in the HDMI signal and separately as Toslink and analog stereo providing maximum flexibility for systems integration.
The 1T-VS-626 is both HDMI v1.1 and HDCP 1.1 Compliant. It has a maximum resolution of 1080p and WUXGA for both the input and output. It will also accept 480i or 576i SDTV resolutions. Advanced features, such as 3D Motion Adaptive De-Interlacing, 3:2 and 2:2 Pull-Down and 50/60 Frame Rate Conversion provide extremely high quality signal conversion. A comprehensive OSD menu and buttons allows selection of output resolution, adjustments of picture quality and audio source selection. It’s also possible to add up to 150ms of audio delay to compensate for lip sync errors. A small inline power adapter is provided with a locking DC connector for security.
This product is available to order now and has a recommended retail price of £169 (€249).
The TV One product line can be viewed on their website www.tvone.eu, alternatively you can contact their European Sales and Technical Department on +44 (0) 1843 873311 or at sales.europe@tvone.com.
