Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through June 03, 2008 >
Ominmount Expands Low Profile Series to Include Fixed Mounts
| Posted by Marketing Ma... on Thursday, May 29, 2008 - 10:26 am: |
PHOENIX, Ariz. May 29, 2008 OmniMount, dedicated to being a one-stop shop for professional products, has expanded its Low Profile Series to include fixed versions of its award-winning low profile tilt mounts, ideal for applications where tilt functionality isnt necessary. Appropriately named the Low Profile Series, this line features a remarkably slim mounting profileonly 1.5 off the wall in the fixed positionthat ensures that flat panels blend seamlessly into any environment and collectively address every price point and application in the market. The LPHDM-F, LPHDL-F, and LPHDX-F fixed mounts and the LPHDM-T, LPHDL-T, and LPHDX-T tilt mounts support flat panels from 26- 42, 40-63 and 55-75 respectively.
OmniMount is dedicated to providing ideal mounting solutions for numerous applications an excellent example is the Low Profile Series, said Hal Truax, general manager of OmniMounts Commercial Division. With its versatile and streamlined design, the Low Profile Series of tilt and fixed wall mounts can be used in a wide variety of settings, all the while ensuring that the flat panel blends seamlessly into every environment.
The Low Profile Series is manufactured with the best quality standards in the industry including durability, functionality and design. Available in medium (M), large (L) and extra large (X), these low profile mounts are made from heavy-grade steel, have a durable black powder coat finish and include extruded aluminum end caps that present a clean side view. This line also includes all the features installers are accustomed to from OmniMount: Lift n Lock for easy installation, locking system for added safety and security, sliding lateral on-wall adjustment, universal rails for maximum flat panel compatibility, open architecture for simplified wiring and an easy-to-use installation template.
To make mounting and wiring flat panels even easier, OmniMount has designed an innovative built-in kickstand so access to wiring post-installation requires only one person and no vertical lifting of the flat panel. When in use, the kickstand holds the bottom of the flat panel away from the wall so only one person is needed to complete the wiring. The Low Profile Series is available now. OmniMounts tilt mounts retail for $199.95 (LPHDM-T), $299.95 (LPHDL-T), and $329.95 (LPHDX-T) while the new fixed mounts retail slightly lower for $149.95 (LPHDM-F), $199.95 (LPHDL-F) and $249.95 (LPHDX-F).
LPHDM-F Medium Low Profile Flat Panel Fixed Mount
Product Features:
Low profile design only 1.5 off the wall
Includes complete Grade 5 hardware kit
Includes installation template
Sliding lateral on wall adjustment
Open architecture for trim out
Includes security hardware
Locking system for added safety and security
Aluminum end caps included to conceal mounting hardware
Built-in kickstand allows for easy wiring access
Extruded aluminum end cap presents clean side view
Product Specifications:
Supports most flat panels from 26- 42, 125 lbs
Universal and VESA compliant
Double-stud mounting
Available in black
LPHDL-F Large Low Profile Flat Panel Fixed Mount
Product Features:
Supports most flat panels from 40- 63, 200 lbs
Available in black
LPHDX-F Extra Large Low Profile Flat Panel Fixed Mount
Product Features:
Supports most flat panels up to 75, 300 lbs
Triple-stud mounting
Available in black
LPHDM-T Medium Low Profile Flat Panel Tilt Mount
Product Features:
Low profile design only 1.5 off the wall in the fixed position
Tilts +15°
Available in black
LPHDL-T Large Low Profile Flat Panel Tilt Mount
Product Features:
Tilts +15°
Available in black
LPHDX-T Extra Large Low Profile Flat Panel Tilt Mount
Product Features:
Tilts +15°
Available in black
Talking Points:
OmniMount has expanded its Low Profile Series to include fixed version of its low profile tilt mounts supporting flat panels ranging from 26- 75.
The Low Profile Series has a cutting edge design and the innovative kickstand feature
Available now, the LPHDM-T, LPHDL-T, and LPHDX-T retail for $199.95, $279.95 and $329.95 respectively, while the LPHDM-F, LPHDL-F, and LPHDX-F retail slightly lower for $149.95, $199.95 and $249.95, respectively.
About OmniMount
For nearly 30 years, OmniMount has upheld its position as a global leader by continually evolving the industry through product innovation and the creation of new product categories. Represented worldwide in over 65 countries to date, OmniMount products have been recognized for groundbreaking design, high quality and long-term reliability. Thanks in part to the companys in-house industrial design and engineering team precise attention to detail and quality control standards are built into every product, producing the most breakthrough and well-built products on the market. Today, the OmniMount product line features hundreds of mounting solutions that cover the demands of nearly every application. From the smaller speaker to the largest flat panel and everything in between, OmniMount has been a pioneer in developing professional and consumer products to maximize the home theater experience. For a closer look, visit www.omnimountpro.com.
