Home > Message Board > Press Releases > Archive through 2008 > Archive through June 12, 2008 > Sanyo Xacti HD1010 Camcorder Announced
Xacti-HD1010
SANYO Full HD Camcorder Has 'Face Chaser' Technology for Video and Stills; Features Slow-Motion Video Mode and 7-fps Sequential Shooting
SANYO, a world leading digital camera manufacturer, debuts the Xacti HD1010, an ultra-compact, full 1920 x 1080 (1080i) high-definition digital camcorder featuring "Face Chaser" face detection technology for both video and stills, plus a new slow-motion video mode and seven frames-per-second sequential shooting for superb action photography. The sleek and simple-to-use HD1010 takes 4-megapixel digital still images and records video and stills to convenient SD memory cards or SDHC cards (sold separately) up to 32GB.
The SANYO Xacti HD1010 will be available in the U.S.A. in July 2008 at an MSRP of $799.991.
"The SANYO Xacti HD1010 is our second-generation Full HD camcorder and offers a full complement of innovative features such as automatic 'Face Chaser' face detection for both video and stills, along with improved image processing for even better image quality2," said Tom Van Voy, Vice President and General Manager of SANYO's Audio Video Division. "The HD1010 offers advanced, high-definition video performance and high-quality stills in one small, lightweight device."
Face Detection/Face Chaser Technology
The latest in digital still photography -- Face Detection and Face Chaser technology actually monitor the subject's face and adjust brightness and focus to incredibly clear photos. This technology can be used to recognize up to 12 faces at a time in both video and still photos.
Slow-motion Video Mode
For great sports videos and many other fast-action video projects, the HD1010 can record video at 300 frames-per-second3 to produce smooth, super slow-motion 60fps video playback.
7 Frames-per-second Sequential Shooting
Shoot digital still images like the pros with up to seven photos in a single second. Ideal for special effects or action photography.
Small and Light Full HD Camcorder
The HD1010 weighs only 9.9 ounces (with battery and SD card). It incorporates advanced MPEG-4 AVC/H.264 video compression, enabling up to approximately 87 minutes of Full HD (1920 x 1080) video recording on an 8GB SDHC memory card (sold separately).
Wide Dynamic Range Mode
Wide Dynamic Range Mode allows improved images in varying degrees of light and shade.
Four Megapixel Digital Images
The Xacti HD1010 enables simultaneous shooting of 4-megapixel still images and HD movie clips, with a simple press of the shutter button during the recording of a video clip. Users need never miss another precious photo opportunity. (Depending on the mode used to take still images, simultaneous video clip shooting may be interrupted. While shooting video clips, using the digital image stabilizer may change the angle of view for still images.)
Comfortable Ergonomic Design
The HD1010 is designed for easy, one-handed operation with "one thumb" operation of all key functions. The camcorder is comfortable to hold, even for extended periods.
Full 1080i HD Sensor
Incorporating the latest high-definition CMOS sensor, the SANYO Xacti HD1010 captures full 1080i high-definition video (1920x1080) at 60 frames-per-second. Designed to record the rich and vibrant colors of real life, the HD1010 also captures subtle tones to provide a natural-looking result. SANYO's latest high-speed image processing engine capably handles the high capacity demands of Full HD data. Signal processing has been optimized for gamma correction and noise reduction, improving lens color-sensitivity and image quality when filming in darker locations. In addition, the video codec algorithm has been adjusted from 12 to 14 Mbps to allow more data per second, for improved imaging.
10x Optical HD Zoom Lens
At the front of the HD1010 is a commanding 10x all-glass HD lens. The camcorder's fast f/1.8-2.5 lens is capable of allowing almost four times more light through to assist in lower light venues. Consisting of eight groups and eleven total lenses with a built-in neutral density filter, the HD1010's lens provides a spectacular field-of-view with a 38-380 mm range (35 mm equivalent).
Image Stabilization
High-definition can't hide shaky or erratic camera movement. So, SANYO's HD1010 comes with a sophisticated image stabilizer for both stills and video. This handy feature operates in both wide-angle and telephoto modes, giving every shot a solid, professional-looking feel. Image stabilization allows for clear pictures of the subject even when moving or rotation occurs.
Large 2.7-inch Widescreen Display
The HD1010 features a large 2.7 inch widescreen Liquid Crystal Display (LCD). The display flips out from the camera and rotates up to 285 degrees on axis, allowing you to take great video or still images even from difficult-to- view positions, which is especially useful when shooting in large crowds or in small rooms.
HDMI High-definition Output
It's easy to view and share high-definition video on your HD television with the HD1010. Using the HDMI (High-Definition Multimedia Interface) terminal built into the base station, just one cable connects your camcorder to your TV for a totally digital output. HDMI carries both the video and audio signals in digital form for the highest quality playback.
Easy Camera to PC Connection
SANYO's HD1010 streamlines the confusing and complicated component connection process with an innovative docking station. This dock provides instant connectivity via HDMI cable (sold separately), component, composite or S-video connection to a TV, DVD player and computer. The HD1010 even recharges its internal battery when nested in the docking station.
Records to Convenient SD/SDHC Memory Cards
The SANYO Xacti HD1010 records high-definition and photos directly to a standard SD or SDHC Memory Card. The camcorder is capable of recording up to 87 minutes of 1080i high-definition video on a single 8GB card (sold separately). When connected to a computer via the USB cable, the HD1010 acts as a standard card reader. Transferring images and videos to your computer has never been easier.
Xacti-HD1010
Addition HD1010 Features:About SANYO
SANYO Electric Co., Ltd. is a multi-billion-dollar global leader in providing solutions for the environment, energy and for lifestyle applications based on its Brand Vision 'Think GAIA'. SANYO Fisher Company (a division of SANYO North America Corporation, a subsidiary of SANYO Electric Co., Ltd.), based in Chatsworth, California, markets digital still cameras, digital media camcorders, digital projectors, home appliances, security video equipment, audio systems, portable and mobile electronics and HD televisions.
All products and trademarks are the property of their respective owners. Because its products are subject to continual improvement, SANYO reserves the right to modify product design and specifications without notice and without incurring any obligations.
  1. Manufacturer's Suggested Retail Price. Pricing subject to change at any time. Actual prices are determined by individual dealers and may vary.
  2. Compared to the SANYO Xacti VPC-HD1000
  3. Still images and zoom can not be used simultaneously with 'slow-motion' filming. Focus/exposure and digital image stabilization not available in this mode. For this model 300fps is actually 299.7fps
  4. Recorded as 4.0 Mega-pixels
  5. Recorded as 2.0 Mega-pixels
