Home > Message Board > Press Releases > Archive through 2008 > Archive through June 12, 2008 > Motorola H620 and H560 Bluetooth Headsets Announced
Motorola H620 and H560 Are the Ideal Blend of Clarity and Comfort, Optimized for In-Car and on the Go Environments
Motorola, Inc., the global market leader in Bluetooth enabled accessories today announced two new Bluetooth enabled headsets, the Motorola H620 and Motorola H560. Featuring noise reduction and echo cancellation technology and TrueComfort™ design, these new headsets are compatible with over 200 Bluetooth enabled devices from over fifteen brands. The H620 is a complete in-car solution while the H560 allows consumers to stay hands-free while on the go.
“Consumers can depend on Motorola for quality Bluetooth enabled headsets that deliver both an outstanding audio experience and comfort with style,” stated Jason Few, corporate vice president & general manager, Motorola Companion Products. “With the H620 and H560, Motorola is continuing to offer consumers hands-free solutions that fit their life, whether it’s a headset specifically designed for the car or an on the go busy lifestyle.”
H620
Motorola Universal Bluetooth In-Car Headset H620
The first ever Motorola Bluetooth enabled headset optimized for the car, the Motorola H620 offers clear and comfortable hands-free conversations.1 Road noise will be a thing of the past with H620’s noise reduction and echo cancellation technology. In addition, the volume automatically adjusts as road noise increases to deliver clear calls for both people in the conversation.
With a dashboard headset holder and rapid in-car charger, the H620 is an ideal in-car solution. The sleek headset also supports phone voice dialing to keep users eyes on the road, Motorola’s patented TrueComfort design, EasyPair technology and a discreet three-color indicator light that enables users to check the battery level.
H560
Motorola Universal Bluetooth Headset H560
The Motorola H560 delivers quality audio and comfort in a distinct design. The H560 improves call clarity on both sides of the conversation with noise reduction and echo cancellation technology as well as automatic volume control that increases or decreases the volume based on the noise level in the surrounding environment.
The H560 features TrueComfort design that channels clear audio directly into the ear. Multiple sizes of ear cushions ensure the best fit to create a seal that helps reduce background noise. EasyPair technology makes it simple to connect with more than 200 models of compatible Bluetooth enabled devices, and a discreet, three-color battery indicator light enables users to check battery life.
Availability
The H620 and H560 are expected to be available in Q3 2008.
