Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through June 12, 2008 >
TV One’s Professional Analog and DVI Cross Converter Now Shipping
| Posted by Debbie Heath on Thursday, June 12, 2008 - 11:58 am: |
Advanced features, such as 3-D Motion Adaptive De-Interlacing and 3-D Noise Reduction, provide extremely high quality signal conversion. An OSD (On Screen Display) menu system makes the 1T-VS-558 easy to set up and control using the front panel joystick or the Infrared Remote Control. An Auto Adjust button allows for the automatic size and position of the image. DVI Inputs and Outputs are fully HDCP Compliant.
The unit requires external 5VDC and an AC Adapter is provided. It has a locking DC connector for added security. An optional RM-220 Rackmount kit is available that can house either one or two units. The unit has a suggested retail price of £298 (€386) and is available now.
More information regarding this unit along with the entire TV One product line can be found on the TV One website, www.tvone.eu, alternatively you can contact the European Sales and Technical Department on +44 (0) 1843 873311 or at sales.europe@tvone.com.
