Home > Message Board > Press Releases > Archive through 2008 > Archive through June 12, 2008 > TV One Releases Video Scaler that will Up/Cross Convert to HDMI with Audio
The 1T-VS-658 from the TV One-task line is a professional Up and Cross Converter with an HDMI output. The video inputs include HDMI, DVI (via the HDMI connector), Analog RGB/YPbPr via HD-15, Analog YPbPr or 480i/576i YUV Component via three RCA, S-Video (YC) and Composite Video. There are Five Analog Stereo inputs and a SPDIF Coaxial Digital Audio input available for embedding into the HDMI output. A separate Coaxial Digital Audio output is also provided and audio delays of up to 150ms can be introduced to ensure lip sync.
The 1T-VS-658 handles Input and Output Resolutions up to 1080p and WUXGA. The HDMI is fully HDCP compliant and is compatible with HDMI v1.2 standards. Advanced features, such as 3D Motion Adaptive De-Interlacing, 3D Noise Reduction and 8-bit triple ADC/PLL technology, combine to provide extremely high quality signal conversion.
An On Screen Display menu makes the 1T-VS-658 easy to set up. Control is via front panel joystick and buttons, Infrared Remote or RS-232 interface. The unit requires external 5VDC and an AC Adapter is provided. It has a locking DC connector for added security. An optional RM-220 Rackmount kit is available that can house either one or two units.
The unit has a suggested retail price of £319 (€413) and is available now.
More information regarding this unit along with the entire TV One product line can be found on the TV One website, www.tvone.eu, alternatively you can contact the European Sales and Technical Department on +44 (0) 1843 873311 or at sales.europe@tvone.com.
