Home > Message Board > Press Releases > Archive through 2008 > Archive through July 02, 2008 > Loiminchay Audio Degas Speaker System
+ Share | Create New | Reply | Edit
C:\Documents and Settings\Administrator\My Documents\00 Scull Communications\00 Loiminchay\Logos\loi_logo.jpg
Loiminchay Audio Speakers
The Perfect Fusion of Art and Science
The Degas
“Art is not what you see, but what you make others see.”
-- Edgar Degas
C:\Documents and Settings\Administrator\My Documents\00 Scull Communications\00 Loiminchay\photos\loiminchay_degas\rel.jpg
Loiminchay Audio hand-crafts luxurious, extreme performance, limited-edition speakers for connoisseurs. They’re artist inspired and artisan crafted for a unique and exceptional appearance and a totally remarkable musical experience.
They’re designed in New York by owner Patrick Chu, a maker of world-famous luxury-quality Loiminchay pens, sought after by collectors around the world. Patrick celebrates the same artistic passion with his Loiminchay speaker systems. They’re hand made by dedicated teams in his atelier in China. Each heavily-braced enclosure is painstakingly crafted, layer by layer, from beautifully formed Birch MultiPly laminate resulting in a sensually shaped, extremely nonresonant structure. The cabinets are bored out then finished inside and out with fully sixteen coats of the finest hand-polished lacquer for a lustrous cabinet so finely sealed that no air bubbles remain to potentially leak internal pressurized air. Loiminchay employ three people just to route the interior and driver holes, and even the baffles are hand-shaped in the laminate during fabrication.
Loiminchay’s stand-mounted monitor brings your music to expressive life. The enclosure is fabricated of beautifully sculpted 30mm/1.2-inch Birch MultiPly laminate with sturdy internal bracing and top-quality lamb’s wool filling. The Degas, like the Chagall, can be supplied with a 30mm/1.2-inch ceramic tweeter that tops out at 28kHz, while the sparkling diamond tweeter extends out to 40kHz for unmatched texture and nuance in the upper frequencies.
The Degas’s high-performance 6.8-inch ceramic midrange driver delivers excellent bass down to 40Hz (ceramic tweeter) or 32Hz (diamond tweeter) for a solid musical foundation. The Degas is available with an elegant, beautifully hand-made stand fashioned of 25mm/0.98-inch Birch MultiPly, sand-filled, with binding posts conveniently located near the solid aluminum base plates.
Either version of the Degas is easy to drive with 90db/2m (diamond tweeter) or 89dB/2m (ceramic tweeter) sensitivity at 8 ohms and 100 watts of power handling. The Degas is single-wired with a silver internal wire harness and heavy-duty binding posts, weighing about 80 lbs on its stand.
Measuring Up
“Measurements are very important but only part of the story,” explains Patrick. “Everything makes a difference in the sound; the choice of drivers, the shape and density of the cabinet, how well it’s braced, the quality and quantity of the lamb’s wool stuffing, how the sound waves flow around the cabinet’s exterior surfaces, and even which lacquer finish you choose! That’s right, the two-way Degas in black piano lacquer sounds slightly different than a Degas with a MultiClear lacquer finish. It’s the same with the Chagall, and that’s why every pair’s crossover is optimized for the best possible overall sound.”
A New Means of Expression
It is said of Degas that his energy, shimmering, nuanced movement and subtly layered colors were ways of looking for an entirely new means of expression. His was a detailed, rich and intimate viewpoint, so alive the viewer feels they’ve just stumbled upon the painted scene.
This stunning sense of reality is but one of the Degas’ many strengths, especially equipped with the extraordinary diamond tweeter. Their imaging is above expectation even for high specification stand-mounted speakers; they disappear into a startling transparent, dimensional and palpable soundstage. The ceramic and especially diamond tweeters deliver extraordinary air over sparklingly open and detailed upper frequencies. The tweeters are artfully blended with the midrange producing a rich, elegant and beautifully musical sound.
The Degas is a dynamic, passionate performer, delivering an engaging, intimate contact with music of all kinds. It rises to the musical and emotional occasion each and every time you listen. Its exotic, sculptural shapes reveal an extraordinary build quality, complemented by the deep natural luster of clear lacquer over Birch, or a deep and rich piano lacquer finish. You can order yours in custom-made in cherry.
Loiminchay speakers reproduce the precise to the passionate: Glenn Gould caressing his master’s voice or Vladimir Horowitz in full expressive flight. Loiminchay effortlessly takes you to the very essence of the music.
Experience the Art of Performance!
Patrick Chu,
President Loiminchay Audio
Loiminchay • 46-39 Parsons Boulevard, Flushing, NY 11355
212.941.7488 • info@loiminchayaudio.comwww.loiminchayaudio.com
For Reviews, Press Information and Photos Contact
Jonathan Scull • Scull Communications
jscull@scullcommunications.comwww.scullcommunications.com
212.807.0519
