Home > Message Board > Press Releases > Archive through 2008 > Archive through July 15, 2008 > Nikon Announces New PC-E NIKKOR Series Lenses
The PC-E Micro NIKKOR 45mm f/2.8D ED and PC-E Micro NIKKOR 85mm f/2.8D Lenses Offer Perspective Control
Nikon Corporation is pleased to announce the introduction of the two new PC-E NIKKOR Perspective Control lenses, with tilt/shift function, for digital and 35mm-fomat film SLRs -- the PC-E Micro NIKKOR 45mm f/2.8D ED and the PC-E Micro NIKKOR 85mm f/2.8D. Together with the PC-E NIKKOR 24mm f/3.5D ED, released in February 2008, the PC-E NIKKOR series now covers a range extending from 24mm wide-angle to medium telephoto 85mm.
The PC-E NIKKOR lens series features a tilt/shift mechanism that provides extraordinary control over the relationship between the optical axis of the lens and the image plane, thereby enabling Perspective Control. This function proves particularly valuable for specialized professional users such as architecture and product photographers.
PC-E Micro NIKKOR 45mm f/2.8D EDPC-E Micro NIKKOR 85mm f/2.8D
45mm85mm
Incorporating an electromagnetic diaphragm, these lenses provide auto aperture control when used with D3, D700 and D300 digital SLR cameras for improved operability. Furthermore, Nano Crystal Coat effectively reduces ghosting and flare to provide sharper, more vivid images. This contributes to the superior optical performance of these lenses to realize the outstanding image quality for which NIKKOR interchangeable lenses are renowned.
Note: "PC" in the lens name stands for Perspective Control.
Perspective control with tilt/shift function
All PC-E NIKKOR lens with Perspective Control capability incorporate a special tilt/shift mechanism. The shift mechanism enables the lens to be moved parallel to the image plane, so that subjects such as a tall building can be captured faithfully, without the upper part appearing to tilt backward and become thinner. The tilt mechanism changes the orthogonal relationship between the optical axis of the lens and the image plane, allowing you to control the focused area. In landscape photography, you can achieve a focus throughout the entire subject plane from near to distant. You can also achieve focus on a specific part of the subject for emphasis. In actual shooting situations, the shift and tilt mechanisms are used together to adjust perspective, distortion of the subject, and focus area.
Major Features
Note:
These lenses can be used with the D3, D700 and D300 without any limitation; and can also be used with the following cameras, though some restrictions or limitations on functions exist: D2 series, D1 series, D200, D100, D80, D70 series, D60, D50, D40 series, F6, F5, F4 series, F100, F90X/N90s, F90 series/N90, F80 series /N80 series, F75 series /N75 series, F65 series /N65 series, and PRONEA 600i/6i.
PC-E Micro NIKKOR 45mm f/2.8D ED Specifications
Focal length 45 mm
Maximum aperturef/2.8
Minimum aperturef/32
Lens construction9 elements in 8 groups (with one ED glass element and Nano Crystal Coat)
Picture angle51° (maximum 66° when fully shifted)
Closest focus distance0.253 m (0.83 ft.)
Maximum reproduction ratio1/2
No. of diaphragm blades9 (rounded)
Filter/attachment size77mm
Diameter x lengthApprox. 82.5 x 112 mm/3.2 x 4.4 in. (extension from lens mount)
Weight Approx. 740 g/26.1 oz.
Supplied accessories77mm Snap-on Front Lens Cap LC-77, Rear Lens Cap LF-1, Bayonet Hood HB-43, Flexible Lens Pouch CL-1120
PC-E Micro NIKKOR 85mm f/2.8D Specifications
Focal length 85 mm
Lens construction6 elements in 5 groups (with Nano Crystal Coat)
Picture angle 28°30’ (maximum 37°50’ when fully shifted)
Closest focus distance0.39 m (1.3 ft.)
Diameter x lengthApprox. 83.5 x 107 mm/3.3 x 4.2 in.
Weight Approx. 635 g/22.4 oz.
Supplied accessories77mm Snap-on Front Lens Cap LC-77, Rear Lens Cap LF-1, Bayonet Hood HB-22, Flexible Lens Pouch CL-1120
