Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through July 15, 2008 >
TV One Introduces New Analog/Digital Video Format Converters
| Posted by Debbie Heath on Monday, July 07, 2008 - 07:48 am: | + Share | Create New | Reply | Edit |
TV One-Task units are renowned for being simple yet powerful products that are designed for one purpose only, ensuring ease of use and low costs. These two new Format Converters are no exception giving premium-quality results converting between digital and analog formats without any video scaling. The 1T-FC-524 will convert to several other formats if DVI is not available. An analog YPbPr input can be converted to either digital YPbPr or RGBHV. An analog RGBHV input can be converted to digital RGBHV.
The output resolution is the same as the input. All standard HDTV resolutions are supported on both products from 480p through 1080p, plus SDTV resolutions of 480i and 576i. PC resolutions up to 1600x1200 are supported. They will also handle DVI Bandwidth to 1.65Gbps (Single Link.)
Both models are 5VDC powered and the Power Adapters are included. Locking DC Connectors are provided for security. They are also plug-and-play so no setup is necessary. The units have a suggested retail price of £119 (€ 154) and are available now.
More information regarding these new Format Converters along with the entire TV One product line can be found on the TV One website, www.tvone.eu. Alternatively you can contact the European Sales and Technical Department on +44 (0) 1843 873311 or at sales.europe@tvone.com.
