Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through August 12, 2008 >
Sony RHT-G500 BRAVIA Theatre Integrated TV Stand Announced
| Posted by Admin on Tuesday, August 05, 2008 - 10:57 pm: |
- 'Home theatre in a stand' designed for use with 32-40in BRAVIA TVs
- S-Force PRO Front Surround for superb virtual surround sound without any rear speakers
- BRAVIA Sync for one-button operation of a complete system
- HDMI connections compatible with the latest HD TV formats
All you see is a sleek-looking TV stand, the perfect partner for BRAVIA LCD TVs - but thanks to advanced signal processing technology, you also hear remarkable sound effects all around you.
Surround-sound from a TV stand
The RHT-G500 uses a 3.1-channel sound system, with centre, left and right speakers and subwoofer built into the TV stand. Using S-Force PRO Front Surround technology, the RHT-G500 creates a soundfield that not only fills the room, but also envelops listeners in breathtaking surround sound effects. This means you enjoy great surround sound without rear speakers or messy wires.
Audio inputs for TV, DVD and Blu-ray Disc
The RHT-G500 can accept sound from a wide range of sources: the TV, DVD players and satellite/cable/terrestrial digital set-top boxes. It even delivers high-definition sound from a Blu-ray Disc player or PLAYSTATION®3, opening up a whole new world of high-definition audio.
BRAVIA Sync allows a complete system - DVD or Blu-ray Discä player, BRAVIA TV and surround-sound - to be operated from a single remote control, using control signals carried on the HDMI connections. For example, simply pressing 'play' on the remote will turn on all devices simultaneously and start playing your movie in engrossing surround sound.
HDMI pass-through with 1080p / 24p / x.v.Colour compatibility
To make the connection of a complete system as simple as possible, the RHT-G500 has three HDMI inputs and a monitor output, and these can pass through superb high-definition video from a Blu-ray Disc player to one of Sony’s latest BRAVIA LCD TVs.
DIGITAL MEDIA PORT for all your mobile music
The RHT-G500 also allows you to connect portable players, Bluetooth® devices and even a Wi-Fi network, to enjoy your music through its amplification and speakers. It’s all made possible by the DIGITAL MEDIA PORT and its range of modular adapters, while a built-in Portable Audio Enhancer system will also improve the sound quality of tracks stored on these mobile music devices.
Simple, intuitive operation
The RHT-G500 comes complete with a remote control, and has a clear, easy-to-read display on its front panel. It really is home theatre made simple - and invisible!
Environmental Info
Sony is engaged in a constant review of its manufacturing, operational and business practices to ensure that its products are developed in an environmentally responsible way. This approach can broadly be divided into three areas:
- PRODUCT: The RHT-G500 BRAVIA Theatre surround sound TV system consumes only 0.3W in Standby mode. The full digital amplifier S-Master from Sony can achieve over 85% power efficiency.
- PROCESS: Halogenated materials may pose a risk to the environment if disposed of improperly. To minimize this risk for the RHT-G500, the flame retardants of all cover/housing parts and the printed circuit boards are halogen-free.
- PLANET: Sony is determined to lead the way as a responsible manufacturer, and as a result we are focussing on three key areas of investment:
- Reducing CO2 gas emissions
- Increasing the percentage of renewable energy used in manufacturing facilities
- Minimising the resources used by our factories in manufacturing
